VS-3-5AX
  1. Vertical Mills
  2. Extra-Large VMC
  3. VS-3-5AX
VS-3-5AX
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis Vertical Machining Center; 150" x 50" x 50" (3810 x 1270 x 1270 mm)
The Haas VS-3-5AX is a large-frame, bed-style machining center that provides large travels and 5-axis cutting capacity in a vertical spindle format. The machine features a 20,000-rpm HSK-A63 spindle and a 70+1 tool side-mount tool changer.
The Haas-built dual-axis head supports the spindle from both sides for rigidity, and has powerful brakes on both axes for accurate 3+2 machining. The rotary head provides ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt to reach nearly any angle.
The fully supported X-axis travels easily handle parts weighing up to 10,000 lb (4536 kg). The table surface consists of three blank tooling plates that are easily machined for custom fixturing.
NOTE: A T-slot table can be subsituted for the tooling plate table at the time of order.
  • Haas-built dual-axis head supports the spindle on both sides for rigidity
  •  ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • Powerful brakes on the B and C axes for accurate 3+2 machining
  • 70+1 side-mount tool changer
  • Control pendant on moveable stand for easy access
  • Fully supported X-axis travel w/ 10,000 lb (4536 kg) part capacity
  • 50 mm ballscrews on all axes
  • 153" x 49" (3886 x 1245 mm) table, with 3 blank bolt-on tooling plates for custom fixturing
See Available Stock
Current Lead Time
  • HSK-A63 Taper
  • 5 Axis
  • 20k RPM
  • 70+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
  • Rotary Fit Chart
Travels S.A.E METRIC
X Axis 150.00 in 3810 mm
Y Axis 50.00 in 1270 mm
Z Axis 50.00 in 1270 mm
Spindle Nose to Table (~ max) 55.0 in 1397 mm
Spindle Nose to Table (~ min) 5.0 in 127 mm
Spindle S.A.E METRIC
Max Rating 29.0 hp 21.6 kW
Max Speed 20000 rpm 20000 rpm
Max Torque 20.0 ft-lbf @ 7500 rpm 27.0 Nm @ 7500 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper HSK-A63 HSK-A63
Bearing Lubrication Grease Packed Grease Packed
Cooling Liquid Cooled Liquid Cooled
B Axis - Tilt S.A.E METRIC
Travel ±120˚ ±120˚
Max Speed 112 °/sec 112 °/sec
Torque (Continuous) 470 ft-lbf 639 Nm
Brake Torque 454 ft-lbf 616 Nm
C Axis - Rotation S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Speed 208 °/sec 208 °/sec
Torque (Continuous) 285 ft-lbf 386 Nm
Brake Torque 442 ft-lbf 600 Nm
Table S.A.E METRIC
Length 153.0 in 3886 mm
Width 49.0 in 1245 mm
Thickness 1.9 in 48 mm
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Feedrates S.A.E METRIC
Max Cutting 360 ipm 9.1 m/min
Rapids on X 360 ipm 9.1 m/min
Rapids on Y 600 ipm 15.2 m/min
Rapids on Z 600 ipm 15.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4000 lbf 17793 N
Max Thrust Y 4000 lbf 17793 N
Max Thrust Z 6300 lbf 28024 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 70+1 70+1
Max Tool Diameter (full)** 4.0 in 102 mm
Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
Max Tool Length (from gage line) 6.00 in 406 mm
Max Tool Weight 30.0 lb 13.6 kg
Tool-to-Tool (avg) 6.00 s 6.00 s
Chip-to-Chip (avg) 15.00 s 15.00 s
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 20000 rpm 20000 rpm
Spindle Power 29.0 hp 21.6 kW
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
AVAILABLE OPTIONS
RELATED PRODUCTS
Standard Features
  • 20,000-rpm Dual-Support Spindle, HSK-A63
  • 70+1 Side-Mount Tool Changer, HSK
  • Wireless Intuitive Probing System
  • Chip Auger
  • Window Air Blast
  • 95-Gallon Coolant Tank
  • Chip Tray Filter Kit
  • Multi-Stage Coolant Pump
  • Control Touch Screen
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • CNC Control Cabinet Cooler
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Dynamic Work Offsets and Tool Center Point Control
  • Rigid Tapping
  • ECO Mode
  • Stainless Steel Way Covers
  • Phone Charging Stand
  • Machine Anchoring Kit
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • INSTALLATION Guide
  • Layout Drawing (Coming Soon)
  • Torque Chart
  • Operator’s Manual
RELATED PRODUCTS
C-Frame VMC
Haas VR-11
VR-14
5-Axis Vertical Machining Center; 150" x 40" x 42", 2-axis head
  • HSK-A63 Taper
  • 5 Axis
  • 20k RPM
  • 50+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
3-Axis Alternative
Haas VS-3
VS-3
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
    CNY ONLY
Smaller 3-Axis
Haas VS-1
VS-1
Vertical Machining Center; 100" x 50" x 50" (2540 x 1270 x 1270 mm)
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
    CNY ONLY
HRT1000 VS-3-5AX POSITIVE FIT
HRT450 VS-3-5AX POSITIVE FIT
HRT800 VS-3-5AX POSITIVE FIT
TR310 VS-3-5AX POSITIVE FIT
Build & Price
Get Started
Need More Information?
