VR-5
  1. Vertical Mills
  2. VR Series
  3. VR-5
VR-5
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis Vertical Machining Center; 50" x 26" x 25", 2-axis head
The VR-5 brings 2-axis spindle head capabilities to our mid-size VMC platform to create a compact 5-axis machine for profiling and contouring mid-size parts. The machine’s smaller footprint – 40% smaller than the large-frame VR-8 – makes it well suited for shops where space is at a premium.
Standard features include a 24,000-rpm integral-motor spindle, a 50+1 side-mount tool changer, and a 54" x 24" (1372 x 610 mm) T-slot table that easily supports longer workpieces and fixtures. The 2-axis gimbaled head provides ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt to access nearly any angle for complex shapes, undercuts, and 5-side machining, and brakes on the B and C axes provide plenty of rigidity for 3+2 machining.
  • 24,000-rpm integral motor spindle
  • ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • 50+1 side-mount tool changer
  • 5-axis simultaneous machining
  • Brakes on the B and C axes for rigid 3+2 machining
  • Includes Tool Center Point Control
See Available Stock
Current Lead Time
  • BT30 Taper
  • 5 Axis
  • 24k RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Available for order in North America only, with estimated 4-month delivery time.
Note: Spindle-nose-to-table dimensions (minimum and maximum) will vary with the orientation of the spindle. See Machine Layout Drawing.
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
  • Automation
Travels S.A.E METRIC
X Axis 50.00 in 1270 mm
Y Axis 26.00 in 660 mm
Z Axis 25.00 in 635 mm
Spindle Nose to Table (~ max) 29.2 in 742 mm
Spindle Nose to Table (~ min) 4.2 in 107 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 24000 rpm 24000 rpm
Max Torque 11.0 ft-lbf @ 5500 rpm 14.9 Nm @ 5500 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper BT30 BT30
Bearing Lubrication Grease Packed Grease Packed
Cooling Liquid Cooled Liquid Cooled
B Axis - Tilt S.A.E METRIC
Travel ±120˚ ±120˚
Max Speed 105 °/sec 105 °/sec
Torque (Continuous) 112 ft-lbf 152 Nm
Brake Torque 100 ft-lbf 136 Nm
C Axis - Rotation S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Speed 100 °/sec 100 °/sec
Torque (Continuous) 210 ft-lbf 285 Nm
Brake Torque 190 ft-lbf 258 Nm
Table S.A.E METRIC
Length 54.0 in 1372 mm
Width 24.0 in 610 mm
T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
T-Slot Center Distance 3.15 in 80 mm
Number of Std T-Slots 7 7
Max Weight on Table (evenly distributed) 4000 lb 1814 kg
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 710 ipm 18.0 m/min
Rapids on Y 710 ipm 18.0 m/min
Rapids on Z 710 ipm 18.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 4100 lbf 18238 N
Max Thrust Z 4100 lbf 18238 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full)** 2.5 in 64 mm
Max Tool Diameter, Large (adjacent empty)** 5.0 in 127 mm
Max Tool Length (from gage line) 16.00 in 406 mm
Max Tool Weight 12.0 lb 5.4 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 24000 rpm 24000 rpm
Spindle Power 15.0 hp 11.2 kW
Domestic Pallet 168.0 in x 101.5 in x 109.0 in 427 cm x 258 cm x 277 cm
Export Pallet 164.0 in x 91.5 in x 101.0 in 417 cm x 233 cm x 257 cm
Weight 12700 lb 5761.0 kg
Domestic Pallet w/50+1 SMTC 168 in x 102 in x 122 in 427 cm x 260 cm x 310 cm
Export Pallet w/50+1 SMTC 164 in x 92 in x 101 in 417 cm x 233 cm x 257 cm
Weight w/50+1 SMTC 12700 lb 5761 kg
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
AVAILABLE OPTIONS
RELATED PRODUCTS
Standard Features
  • 24,000-rpm Integral Spindle, BT30
  • 50+1 Side-Mount Tool Changer
  • Wireless Intuitive Probing System
  • High-Pressure Flood Coolant
  • Chip Auger
  • Window Air Blast
  • 95-Gallon Coolant Tank
  • Chip Tray Filter Kit
  • Chip Washdown Feature
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • CNC Control Cabinet Cooler
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • Safe Run
  • HaasDrop
  • Dynamic Work Offsets and Tool Center Point Control
  • Rigid Tapping
  • ECO Mode
  • Stainless Steel Way Covers
  • Phone Charging Stand
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Anchoring Template
  • Layout Drawing
  • Operator’s Manual
RELATED PRODUCTS
Different Approach
Haas UMC-500
UMC-500
5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Larger Work Envelope
Haas VR-8
VR-8
5-Axis Vertical Machining Center; 64" x 40" x 42", 2-axis head
  • HSK-A63 Taper
  • 5 Axis
  • 20k RPM
    CNY ONLY
Different Approach
Haas VF-540TR
VF-5/40TR
Trunnion CNC Vertical Mill with 50" x 26" x 25" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
    CNY ONLY
Standard Features
  • Chip Auger
  • Window Air Blast
  • Safe Run
  • HaasDrop
  • Rigid Tapping
  • ECO Mode
Shipping
  • Lifting Provision
Warranty
Available Options
Automation Options
ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
SPACE EFFICIENT
COST EFFECTIVE
EASY TO INTEGRATE
EASY TO LEARN
Build & Price
Get Started
Need More Information?
