8 - Chip Conveyor - Overview
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 8.1 Chip Conveyor - Types and Use Cases
  • 8.2 Chip Conveyor - Brand Identification
RD0096
Revision B - 05/2026
Different Conveyor Types
Belt-Type Conveyor (Standard)
Chips and Coolant Conveyor. Product of Haas CNC machine tools.
Description:
  • Heavy-duty steel belt-type chip conveyor
  • Activated via M-code, or from the control pendant
  • User settings to control cycle interval and duration for automatic operation
  • Automatically reverses if a jam occurs
  • Automatic operation increases energy efficiency
  • Lift angle minimizes coolant carryout
  • Discharges at standard barrel height
Filtration Conveyor
Description:
  • Built-in filtration system
  • Heavy-duty steel chip scraper
  • Automatic reversal upon torque overload situations
Chip-Disc Filter Chip Conveyor
Description:
  • Same features as the belt-type conveyor plus more
  • Built-in disc filtration system 24 mesh disk filter keeps the coolant tank free of chips and debris
  • Integrated backwash system keeps chips on the belt for proper evacuation to chip hopper or barrel (includes additional pump)
    • Backwash system requires continous opertation.
  • Debris-free coolant for better TSC performance
Use Cases of Each Conveyor Type
Belt-type Conveyor (Standard)
  • Works well for all applications
  • Good for coarse large chips with a lot of chip build up
  • Smaller chips may end up inside conveyor or float out with the coolant into the chip tray
  • More daily maintenance of chip tray
  • Not recommended for unattended operation where fine chips are present
Filtration Conveyor
  • Great for smaller chips sizes
  • Filter box collects small chips and keeps them from going back into coolant tank
  • Tailored for machines that are doing finishing operations
  • Scrapping off the bottom means that chips must sink and not float in order to be shuttled out
  • A number of thick stainless steel brushes scrape along the surface of the conveyor filter box to keep the coolant pathways open and maintain proper coolant flow
  • Does not handle solid pieces of material in the conveyor, jamming may occur
Chip-Disk Filtration Conveyor
  • Great for all applications especially instances where less chip maintenance is desired such as unattended operation
  • Has all the same advantages as belt-type
  • The chip-disk filter strains the coolant and keep the small fine chips  from going to the chip tray
  • Good for automation machines which would otherwise need to clear the chip tray consistently
  • Requires continuous operation to ensure proper coolant filtration and flow
RD0076
Revision A - 05/2026
This document will show you how to identify the different brands of chip conveyors to help effectively troubleshoot chip conveyor.
To find the types and uses cases of the different Haas conveyors, refer to Chip Conveyor - Type and Uses Cases - RD0096
Conveyor Brand Identification
Belt-Type Conveyor (Standard) KEYARROW
KEYARROW conveyors will commonly have the company logo and part number located on the front of the head of the conveyor.
Distinct Features:
Ribs along length of neck.
Motor mount / belt tension assembly.
Belt-Type Conveyor (Standard) HENNIG
HENNIG conveyors will commonly have their logo and part number located on the side of the neck of the conveyor.
Distinct Features:
Tear dropped shaped lift points at top of conveyor.
Belt-Type Conveyor (Standard) JORGENSON
JORGNENSON conveyors will comonly have their logo and part number located above the skirt on the front of the head of the conveyor.
Distinct Features:
'U' shaped bar lift points at top of conveyor.
