8c - CDF Chip Conveyor
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 8c.1 - CDF - Maintenance
  • 8c.2 - CDF - Chip Disc Filter Removal/Installation
  • 8c.3 CDF - Hinge Belt Removal/Installation
  • 8c.4 CDF - Motor Replacement
  • 8c.5 CDF - Troubleshooting
8c.1 CDF Chip Conveyor - Maintenance
Revision A - 05/2026
Daily Maintenance
Check the Conveyor Coolant Level
Remove the cover plate and check the coolant level in the conveyor part of the system.
Normal coolant level in the conveyor should remain below the CDF shaft/center [1] of the disc filter assembly.
If it is higher than normal, inspect the filter screen for blockage.
Clean or replace the filter screen as needed to bring the system back into a normal operating condition.
Check the CDF the Backwash System
Check the CDF filtration backwash system for sufficient spray volume.
A banding (slight discoloration) of the filter screen that reflects the position of the spray nozzles [1] is normal and shows the nozzles are effectively washing chips off the filter screen.
Dotted line ( ) represents proper banding pattern on the filter.
Check the Y-Strainer
Remove the cap on the Y-strainer [1] (located on the top of the CDF disc cover) and check for chip build up.
Clean out as required and reinstall the cap.
Empty the Chip Bin
Be careful not to let the bin overflow, otherwise chips can build up at the discharge head and cause a jam.
Depending on chip flow rate, you may need to empty the chip bin more than once a day.
Preventative Maintenance
Check / Adjust Belt Tension
Remove the covers to access the tension bolts
Loosen the jam nut [1] on each side of the conveyor.
Torque the tension screws [2] (one on bearing side, one on motor side) and tighten the jam nuts [1].
Proper tension is 25in-lbs on both sides.
NOTE: Observe the belt running. Belt jamming (stopping) indicates the tension screws are too tight. Belt jumping out of the sprocket indicates tension screws are too loose or uneven. Adjust as needed and tighten the jam nuts.
Visually Inspect Belt For Damage
General inspection of either belt type can be accomplished at the discharge opening at the head of the conveyor (by removal of the slide lid, or through openings in the trough).
To get a detailed inspection of the belt assembly, a complete removal of the belt from the conveyor body is recommended. This will provide complete access to all the integrated components.
Ensure rollers [1] are rotating freely and check for wear.
Check belt shafts [2] for wear.
Ensure that scrapers [3] are still effective – replace if necessary. (hinge belts are equipped with plain and serrated scrapers)
Check hinge plates [4] for damage.
Grease the Take-Up Bearings
The bearings are accessible by removing a cover or plate. A good, general-purpose grease is recommended. Hennig recommends Mobilgrease XHP222.
Do not over-grease or bearing seal damage may result.
Take-up bearings are found on the sides of the discharge head (one on each side of the conveyor).
Remove the cover plates on each side for take up bearing access.
Take up bearings are accessible once cover plates are removed.
Inspect / Clean The Filter Disc Assembly
  1. Wear Plate
  2. Rubber V-Seal
  3. Filter Disc
  4. Filter Screen
  5. Clamp Disc
Remove the disc assembly. See Chip Disc Filter Removal/Installation for filter disc removal and disassembly.
Clean out all chip accumulation in the chip disc filter components (filter disc, filter screen, clamp disc).
Regardless of adequate back-wash spray, filter screens over time can become unusable because chips become embedded in the mesh. Replace the screen if the filter screen cannot be properly cleaned or reduced performance has been observed.
Inspect the rubber V-seal. It should be free of nicks and cuts, and chips should not be embedded in it. Remove all chips before reassembly. Replace seal if there is substantial damage. Check for tension: v-seal should be tight on the disc and not be able to spin.
Inspect the wear plate. There should be no scratches or grooves in it, which could limit its sealing capability. Replace the wear plate if there is substantial wear.
Check the disc drive bearings and make sure all seals are intact.
Re-assemble and install the chip disc filter assembly when disc assembly components have been cleaned and/or replaced.
8c.2 CDF Chip Disk Filter - Removal/Installation
This procedure details how to remove and install the chip disk filter on a CDF conveyor.
Remove the hose from the CDF sprayer.
Remove CDF cover/sprayer assembly [1] by removing the allen head screws and lifting it out of the system.
Loosen the clamp nut lock screw and then remove the clamp nut [1] by turning it off the CDF shaft.
 With the clamp nut removed, now remove the disc assembly [1] by sliding it off the shaft.
Disassemble disc filter assembly (by removing allen head bolts) so components can be properly inspected.
Chip Disc Filter Installation
Position filter screen [2] on filter disc [1].
Install the clamp disc [3] and secure with allen head cap screws.
Coat the seal lip with a generous amount of white lithium grease and press rubber V-seal [1] on filter disc (bearing or axle grease may also be used).
V-seal should not turn on the filter disc.
Slide disc filter assembly on the CDF shaft, but do not press it against the wear plate yet.
Thread the clamp nut on the CDF shaft.
Do not tighten the clamp nut [1] yet.
 Keep threading the clamp nut in (which pushes and positions the disc assembly), until the distance (x) from the CDF wear plate (a) to the edge of the filter disc (c) is 21-23 mm. Check distance every 90° .
Make sure you’re measuring at the edge of the filter disc.
Do not measure to the edge of the filter screen clamp.
  • Wear plate [1]
  • Rubber V-seal[2]
  • Filter disc [3]
  • Filter screen e Clamp disc [4]
Tighten the Allen head cap screw on the clamp nut to secure the CDF assembly
Install the CDF cover/sprayer assembly [1] and secure with allen head cap screws and washers.
Install the hose to CDF sprayer.
8c.4 CDF Chip Conveyor - Motor Replacement
CDF Chip Conveyor - Motor - Replacement
AD0642
This procedure details how to install and wire a replacement motor for a CDF conveyor.
 IMPORTANT: The images in this procedure may show a normal 1/8 HP conveyor motor but the steps will be the same for the CDF conveyor motor.
This procedure will apply to the following kits:
93-3360 CHIPC MOTOR 1/4 HP 240V 50/60HZ 240:1
For Standard coveyor motor replacements refer to AD0345 - Chip Conveyor - Motor - Replacement.
Motor Replacement
Remove the sheet metal enclosure housing the motor.
Remove the cable clamps [1].
Remove the used motor.
Press the 1/4HP CHIP CONVEYOR MOTOR CDF [A] onto the conveyor shaft. Align the slot in the motor shaft with the key [2] on the conveyor shaft.
Attach the motor to the conveyor head.
Install the cable clamps [1].
Connect the electrical cable.
After completing the installation, run the conveyor by pressing [CHIP FWD] if the conveyor runs backwards please check the motor wiring and verify it is wired correctly. Use the wiring diagrams below for reference.
8c.5 CDF Conveyor System - Troubleshooting
CDF - Conveyor System - Troubleshooting Guide
TG0173
Note: Download and fill out the Chip Conveyor System Inspection Report Checklist below before replacing any parts.
This troubleshooting guide explains how to diagnose and resolve issues with a CDF Conveyor System.
For other conveyor types, refer to Section 8a for the Standard Belt Conveyor Troubleshooting Guide and Section 8b for the Filter Conveyor Troubleshooting Guide.
Exploded View
NOTE: TO RECEIVE THE CORRECT TECHNICAL SUPPORT ON YOUR CONVEYOR, IT IS REQUIRED TO TAKE A CLEARLY VISABLE PHOTO OF THE CONVEYOR NAME PLATE AND THE MOTOR SEPCIFICATION PLATE.
The conveyor does not start. The circuit breaker is tripped. Check for a short circuit in the motor or the cable. Refer to the Motor Cable Inspection section.
No power from I/O PCB to the motor. Verify voltage at I/O PCB and the motor.
Blown fuses (I/O-version R and earlier). Check the fuses on the I/O PCB.
The conveyor motor capacitor is defective. Inspect motor capacitor for damage.
The 230V system does not turn ON and the red LED on the motor drive PCB is OFF.  The jumper on the motor drive PCB is incorrectly located or defective.  Make sure that the motor drive PCB has a jumper installed on P3 inbetween pin 1 and 2 (the bottom two pins).
There is no 12V input power.  Make sure that the 12V input power is connected to P2 on the motor drive PCB.
Conveyor is noisy or oscillates between forward and reverse. There is a build up of chips. Clear excessive chips and any obstructions.
The conveyor belt is damaged. Inspect conveyor belt and repair or replace.
The conveyor belt tension is incorrect. Adjust the belt tension.
The auger is noisy or oscillates between forward and reverse. Then Alarm 9906  CHIP CONVEYOR MALFUNCTION is generated. There is an excessive chip build-up or an obstruction. Clear all chips and obstructions from the auger trough and chip chute.
There is no chip build-up or obstruction and machine generates
The auger motor is bound up.
The machine is detecting an overcurrent condition.  Check the discrete input CHIP_CONVEYOR_OVERCURRENT cycles from 0 - 1  or 1 - 0 (0 means overload condition). Check the motor for burnout or binding.
Run the Chip Conveyor Overcurrent Data Collection, refer to the Diagnostic Data Collection procedure for how to run the data collection.
The chip conveyor reverses direction with minimal or no chip build-up.
Chip Auger, Conveyor, may start without operator action, even with doors open.
Machine has software 100.17.000.1016 Update software to 100.17.000.2030 or greater. This problem has been corrected such that the conveyor never restarts automatically. With a Classic Haas Control, the operator can restart the conveyor with the door open. NGC machines that have been updated after October 10th, 2018 will have strict door rules that makes this impossible.
M31 is restarting conveyor timers if the conveyor is already on.
Machine has software prior to 100.17.000.2030 and the conveyor cycle keeps restarting every time a M31 is encountered.
Update software to 100.17.000.2030 or greater. In the new software if a conveyor cycle is already running but in the off state, a M31 will NOT restart the conveyor. The conveyor will follow the cycle it is currently in.
Alarm 9819 CHIP CONVEYOR SHORT CIRCUIT The auger motor start capacitor is at fault. Inspect the auger motor start capacitor for damage.
Alarm 9848 CHIP CONVEYOR MOTOR DISCONNECTED There is no power from the I/O PCB to the motor. Verify the voltage at the I/O PCB and at the motor.
CDF Conveyor runs backwards when commanded to run forward Motor wiring is incorrect. Verify the motor wiring, use the wiring diagrams in the CDF Motor Wiring Section for reference.
Corrective Action:
Inspect the motor cable for any sign of damage. Check for burn marks at the plug. This could be caused by coolant contamination.
Measure the Ohms the across the motor power cable leads [1] at the plug. There should be resistance leg to leg. An open reading suggests a bad motor or cable.
Measure the Ohms on the motor power cable from each power leg to the ground leg [2] of the plug. This reading should be open.
If cable shows a short leg to ground at the plug, disconnect the power cable at the motor and check each motor power lead to the motor chassis [3]. If reading is open, the cable is at fault. If any lead tests short, the motor is shorted.
Voltage
Corrective Action:
Find the chip conveyor motor cable 140 at the I/O PCB. Press [CHIP FWD]. Use a multimeter with needle tip probes to measure the voltage between the black and red wires on the cable.
Have someone press and hold [CHIP REV]. Measure the voltage between the black and white wires. When the I/O PCB operates correctly, each voltage reading is 240 VAC.
If the voltage at the I/O PCB is correct, open the conveyor motor junction box. Use a multimeter with needle tip probes to check for voltage on the power leads at the motor.
If there is no voltage, check the motor and the cable. If there is voltage, check the capacitor. If you verify the voltage and capacitor are correct, inspect the motor drive shaft and keyway.
Fuses
Corrective Action:
Check these fuses at the bottom right corner of the I/O PCB (Fuse type: AGC 5 amp):
  • Single phase motors: FU2 [1] /FU3 [2]. There should be no fuse in FU4 [3].
  • 3 phase motors: FU2 [1] /FU3 [2] /FU4 [3]
A short in the motor or the cable could have blown the fuse
Capacitor
Corrective Action:
Inspect the conveyor motor capacitor for damage. A damaged capacitor will usually have signs of deformation or bubbling on the capacitor casing. This could be caused by a short in the motor or in the cable.
Open the motor junction box. Check the capacitor. Look for burn marks on the case.
Measure the capacitor. Most multimeters can measure capacitance upon manual activation (turn to the correct units of measurement, and push the yellow button). It should be 6 or 9 microfarad as noted on the capacitor's case.
Belt Inspection
Corrective Action:
Inspect the conveyor belt for damage.  Refer to the Maintenance section 8c.1
Corrective Action:
Make sure the belt tension is correct. Refer to the decals on the side of the machine. The correct belt slack for Jorgensen conveyors is 0.25" - 0.38" (6 - 10 mm). The correct belt slack for Hennig conveyors is 0.12" - 0.25" (3 - 6 mm).
CDF Motor Wiring
Run the conveyor by pressing [CHIP FWD] if the conveyor runs backwards please check the motor wiring and verify it is wired correctly. Use the wiring diagrams below for reference.
Electrical Diagram
