12 - Coolant Refill
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 12.1 Coolant Refill - Installation
  • 12.2 Coolant Refill - Calibration
  • 12.3 Coolant Refill - Operation
  • 12.4 Coolant Refill - Maintenance
  • 12.5 Coolant Refill - Troubleshooting
AD0171
Revision B - 05/2026
  1. Coolant Tank Mount
  2. Stand Alone Mount
The Coolant Refill option features include:
  • Automatically monitors the machine coolant level.
  • Mixes shop water supply with coolant concentrate at user controlled ratios.
  • Adds correctly mixed coolant at a specified concentration as necessary.
  • Saves time by keeping the machine operator in front of the machine producing parts and not behind the machine mixing coolant.
 WARNING: DO NOT ADD POWDERED/LIQUID COOLANT ADDITIVES TO THE COOLANT REFILL TANK.  THIS WILL DAMAGE THE SOLENOIDS AND VOID YOUR WARRANTY. ALL ADDITIVES MUST BE ADDED AND MIXED IN THE COOLANT TANK.
This Document Applies to these kits:
  • KIT PN 93-1000287: COOLANT REFILL SYSTEM
  • KIT PN 93-1000572: STAND ALONE MOUNT KIT
Note: Machines that require the stand alone mount must order both service kits.
Updated
Machines that require the Stand Alone Mount Kit are listed below:
  • All UMC-500/SS
  • UMC-750/SS with 120 Pocket SMTC
  • UMC-1000/SS with 120 Pocket SMTC
  • DC-1
  • DC-1/40
  • DC-2
  • DC-2/40
  • DC-4/40
  • Minimill
  • Super Minimill
  • ST-10/Y
  • ST-15/Y
  • PMC-500SS
  • EC-1600/ZT/ZT-5AX
Machine Compatibility
  • Mill software 18.22A or higher.
  • Lathe software 11.18A or higher.
  • Next Generation Control software 100.16.000.1010 or higher.
Tools Required
  • Refractometer
  • Bucket - 2 Gallon
  • Clamp Pliers
Electrical Diagram
Tank Handle - Installation
Install the COOLANT REFILL onto the handle of the coolant tank as shown.
Install the water hose [1] into the elbow fitting [2].
Connect the HOSE [B] to the water supply [1].
Make sure the screen filter [2] is installed in the hose fitting for the water supply.
 Note: The Cone Side Of The Screen Filter [2] Must Point Toward The Water Supply.
Order additional supply HOSES [B] (comes with fitting [E]) from www.HaasParts.com or from any hardware store - 3/8" appliance supply line.
Start the water supply. Check for leaks.
 Note: The water supply must have a pressure of 40-100 psi (2.8-6.9 bar) to correctly produce the desired coolant concentration.
Important: To prevent damage to the solenoid valve, make sure the screen filter is installed to clean the incoming water. Debris in the solenoid valve causes it to stay open. This causes inconsistent coolant mixing, and it could also overfill the coolant tank. Your water supply may require additional filtration. Add an aftermarket water filter [1] with a pressure regulator [2] if your water supply has high mineral content or other debris. The water filter and pressure regulator in the picture are not included.
Install the NIPPLE [C] into the outlet port [1] as shown.
 Note: Move the coolant pumps so that the hole on the tank cover is under the NIPPLE [C].
Install the Fittings: Install a 1/2" nozzle to create backpressure in the system. This is needed for thick concentrate coolants.
  • 58-1122 FITG NPT3/8F NPT3/8F STR BRASS [1]
  • 58-3048 FITG HOSE BARB1/2 NPT3/8M STR BRASS [2]
  • 58-1842 HOSE 1/2 ID PU NYLON BRAIDED [3]
Stand Alone Mount - Installation
This section will show you how to install P/N 93-1000572, Stand Alone Mount Kit.
Put the ORINGS [N] over the SCREWS [L] as shown.
Put the COOLANT REFILL [A] onto the STAND [K] so the SCREWS [L] pass through the slots [1] as shown.
Install the WASHERS [O] and WING NUTS [M] to secure the COOLANT REFILL [A].
Connect the HOSE [P].
Install the parts listed as shown onto the COOLANT REFILL [A].
  • HOSE BARB [Q] 1X
  • HOSE [P] 1X
  • CAP [S] 1X
  • CLAMP [R] 1X
Install the COOLANT REFILL [1] near the coolant tank and coolant connector bracket.
Put the HOSE [3] in the coolant tank [2].
 Caution: The HOSE [3] must be above the tank coolant mixture.
Cut the HOSE [3] as necessary. Secure the hose.
Electrical - Installation
Classic Haas Control:
Connect the ADAPTER CABLE [H] to the CABLE [G].
Connect the ADAPTER CABLE [H] to the P52 connector on the I/O PCB.
Route the cable to the coolant connector bracket.
 Note: The coolant connector bracket is always located near the coolant tank.
Find the location on the coolant connector bracket that has the label COOLANT REFILL [1]. Install the other end of the CABLE [G] at this location.
 Note: Drill a hole on the coolant connector bracket if it does not have this location.
Next Generation Control:
  • Mill: Connect the CABLE [G] to the P36 connector on the I/O PCB.
  • EC-400: Connect the CABLE [G] to the P35 pigtail on the I/O PCB.
  • Lathe: Use the ADAPTER CABLE [K] on CABLE [G] and plug it into P16 and P17 on the I/O PCB.
Find the location on the coolant connector bracket that has the label COOLANT REFILL [1]. Install the other end of the CABLE [G] to this location.
Connect the power cable [2] for the COOLANT REFILL [1] to the CABLE [3] in the coolant connector bracket..
Fill the COOLANT REFILL [1] with 5 gallons of coolant concentrate.
Push [POWER ON].
Classic Haas Control.
Change Setting 7 to OFF.
Push [EMERGENCY STOP].
Set Parameter 1385 to 250.
Change Setting 7 to ON.
Push [CURNT COMDS]. Push [PAGE DOWN] until the [COOLANT REFILL] display shows.
Push [F4] to set the Max gal. coolant added before repleshing concentrate.
Push [Y].
Push [Y].
Push [DIAGNOSTIC].
Navigate to the Maintenance tab [1].
Navigate to the Coolant Refill tab [2].
Select Coolant Refill [3].
Select ON.
Push [ENTER].
Push [F4] [4] to set the Maximum Coolant From Remaining Concentrate.
Push [Y].
Calibrate the Coolant Refill.
Next Generation Control - Coolant Refill - Calibration
Push [DIAGNOSTIC].
Push the [RIGHT] cursor arrows to select the Maintenance tab.
Push the [DOWN] and [RIGHT] cursor arrows to select the Coolant Refill tab.
Fill the Coolant Refill container with 5 gallons of coolant concentrate.
Push [F4] to set the Maximum Coolant From Remaining Concentrate.
Push [Y].
Remove the filler hose from the filler pipe.
Put a bucket under the filler pipe.
Push [F3] to fill the bucket.
Push [F3] again to stop when the coolant mixture fills the bucket.
Measure the concentration of the coolant. Refer to the Maintaining Your Coolant Mixture video.
If the measured concentration is lower than the value for the Coolant Concentrate [1], increase the value for the Concentrate Adjustment [2].
If the concentration is higher than the value for the Coolant Concentrate [1], decrease the value for the Concentrate Adjustment [2].
Repeat the measurements until the concentration matches the value for Coolant Concentrate[1].
Classic Haas Control - Coolant Refill - Calibration
Push [CURNT COMDS]. Push [PAGE DOWN] until the Coolant Refill screen shows [1].
Push [F4] [4] to set the Max gallons of coolant added before replenishing concentrate. Push [Y].
Put a bucket [5] under the filler pipe.
Push [F3] to fill the bucket. Push [F3] again to stop when the coolant mixture fills the bucket.
If the measured concentration is lower than the value for the Coolant Concentration Percent[2], increase the value for the Coolant Concentration Adjust [3].
If the concentration is higher than the value for the Coolant Concentration Percent [2], decrease the value for the Coolant Concentration Adjust [3].
Repeat the measurements until the concentration matches the value for Coolant Concentration Percent [2].
Coolant Refill - Filler Hose - Installation
The filler hose [2] installs into the filler pipe [1].
 Caution: Make sure the filler hose does not touch the coolant [3].
The Coolant Refill assembly does these tasks automatically:
  1. Mixes water with coolant concentrate.
  2. Adds coolant to the coolant tank.
You can set values that control how the Coolant Refill operates. This decreases the work necessary to keep the correct level and concentration of coolant in your tank.
Components
  1. Coolant concentrate container
  2. Water supply hose
  3. Coolant Filler pipe/hose
Use these types of coolant concentrate for the Coolant Refill:
  • Soluble oil
  • Synthetic
  • Semi Synthetic
Requirements
  1. Classic Haas Control: Mill software 18.22A or higher and lathe software 11.18A or higher.
  2. Next Generation Control: Software 100.16.000.1010 or higher.
Refer to the Coolant Refill installation procedure.
Next Generation Control Operation
To view the Coolant Refill page:
Push [DIAGNOSTIC].
Select the Maintenance tab.
Select the Coolant Refill tab.
To set a value:
Highlight a setting. Enter the value. Push [ENTER].
Settings for the Coolant Refill:
Setting Description Default Value Range
Coolant Refill [2] This setting activates or deactivates the Coolant Refill option. Off On or Off
Estimated Coolant Use Per Hour [3] This is the quantity of coolant lost to the environment in an hour of detected coolant use.* 1.0 .01 - 99 gallons/hour
Coolant Concentrate[4] This is the correct coolant concentration necessary for the application. 5 0 - 10 %
Time Between Refills[5] This is the quantity of time between automatic coolant refills. 5.0 0.1 - 999.8 hours
Maximum Coolant From Remaining Concentrate[6] This is the quantity of coolant mixture that flows into the coolant tank before the coolant concentrate container is empty. 500 20 - 1000 gallons
Supply Water Rate [7] This is the quantity of water flow from the water supply. Measure the water flow from the water supply and enter that value here. 2.0 0.1 - 99.9 gallons/minute
Concentrate Adjustment [8]
This is the accurate adjustment of the measured coolant concentration. Increase or decrease this value to make the measured coolant concentration the same as the value in Coolant concentration percent [3].**
0 (-20) - 20
Coolant Level [9] This gauge shows the level of coolant mixture in the coolant tank. N/A N/A
Low Coolant Concentrate Warning[10]
This Low Concentrate icon shows when the value in Maximum Coolant From Remaining Concentrate [6] becomes 40. This lets you fill the coolant concentrate container before it becomes empty.
When the value becomes 0, the Coolant Refill system operation stops. This lets you fill the coolant concentrate container.
To keep the system in operation, fill the coolant concentrate container before it becomes empty.
N/A N/A
*The control monitors coolant use as the quantity of time the pumps are on.
**Refer to the Coolant Refill - Calibration procedure.
Operation - Classic Haas Control
To view the COOLANT REFILL page:
Push [CURNT COMNDS]. Push [PAGE DOWN] until the COOLANT REFILL page shows.
To set a value:
Highlight a setting. Enter the value. Push [WRITE/ENTER].
Estimated gallons of coolant consumed per hour [2] This is the quantity of coolant lost to the environment in an hour of detected coolant use.* 1.0 .01 - 99 gallons/hour
Coolant concentration percent [3] This is the correct coolant concentration necessary for the application. 5 0 - 10 %
Number of hours between refills [4] This is the quantity of time between automatic coolant refills. 5.0 0.1 - 999.8 hours
Max gal. coolant added before replenishing concentrate [5] This is the quantity of coolant mixture that flows into the coolant tank before the coolant concentrate container is empty. 500 20 - 1000 gallons
Gallons per minute supply water [6] This is the quantity of water flow from the water supply. Measure the water flow from the water supply and enter that value here. 2.0 0.1 - 99.9 gallons/minute
Coolant Concentrate adjust percent lean [7]
0 (-20) - 20
Coolant level sensor gauge [8] This gauge shows the level of coolant mixture in the coolant tank. N/A N/A
Low coolant concentrate warning [9]
This REFILL CONC. icon shows when the value in Maximum gallons coolant added before replenishing concentrate [5] becomes 40. This lets you fill the coolant concentrate container before it becomes empty.
N/A N/A
Coolant-Concentrate Filter Cleaning
  1. Remove the cap [1] from the container.
  2. Find the filter screen [2] inside at the bottom of the container. Remove the filter screen.
  3. Clean the filter screen with water.
  4. Install the filter screen and cap onto the container.
ASCO Brand Purge Solenoid
Push [POWER OFF].
Close off the water supply valve to the refill unit.
ASCO air purge solenoid:
  • Remove the red cap [1].
  • Push the solenoid coil assembly [2] down to compress the spring inside.
  • Remove the specification plate [3] by sliding off.
  • Remove the split spring [4] and valve subassembly [5] from the coil assembly [2].
  • Disassemble the valve subassembly [5].
  • Clean the parts with compressed air. Be sure to remove all debris from inside the valve.
  • Apply a thin coat of silicone grease to the body gasket [6].
  • Assemble the components in the opposite order they were removed.
  • Open the primary air valve. Make sure there are no leaks.
SMC Brand Purge Solenoids
Push [POWER OFF].
SMC air purge solenoid:
  • Remove the four screws [1].
  • Remove the solenoid coil assembly [2].
  • Clean the internal solenoid parts [3] with compressed air. Be sure to remove all debris from inside the valve [4].
  • Apply a thin coat of silicone grease to the rubber seals.
FESTO Brand Purge Solenoids
Push [POWER OFF].
FESTO air purge solenoid:
  • Remove the nut [1].
  • Remove the washer [2].
  • Remove the solenoid coil [3]. Note the orientation of the coil.
  • Remove the plug nut [4].
 NOTE: Hold the outside diameter (pictured RED) of the plug nut in the vice with the aluminum jaws to prevent the damage.
  • Remove the spring [5].
  • Remove the valve poppet [6].
  • Use the compressed air to clean the valve body [7] valve poppet and the spring.
  • Clean the old thread sealant off the plug nut threads and apply fresh sealant.
  • Assemble the solenoid in the reverse order.
Coolant Refill Option - Troubleshooting Guide
TG0055
Revision A - 02/2026
Exploded View
  1. COOLANT REFILL SOLENOID COIL CABLE
  2. WASHER 1 STEEL .120THK X1.562O
  3. STRN RLF PG13.5 .12"-.27" CD13BR-BK-N
  4. COOLANT REFILL OPTION CHASSIS
  5. FITG NPT1/8F NPT1/8F 90 BRASS
  6. NIPPLE HEX 1/8 NPTM X 3/8 SMOOTH
  7. NIPPLE 1/8 NPT X 2 BRASS
  8. SOLENOID AIR 2 P0RT 2 POS 1 COIL 1/8NPT
  9. NIPPLE 1/8 NPT X 1 HEX BRASS
  10. FITG NPT1/8M NPT1/8F NPT1/8F TEE BRASS
  11. VENTURI NOZZLE
  12. FITG REDUCER NPT1/4F NPT1/8M STR BRASS
  13. FBHCS 1/4-20 X 1/2 LOCTITE
  14. COOLANT REFILL OPTION COVER
  15. FITG COMP 3/8 X 1/4 MNPT 90 BR
  16. FITG NPT1/4F NPT1/4F STR BRASS
  17. NIPPLE 1/4 NPT X 3 1/2 BRASS
  18. FITG REDUCER NPT3/8M NPT1/8F BRASS
  19. STRN RLF PG13.5 .12"-.27" CD13BR-BK-N
  20. FITG NPT3/8 X DIA 1.000 BKHD BRASS
  21. FITG HOSE BARB-3/8 X NPT-3/8-M 90
  22. FITG BLKHD NPT3/8M/F X NPT3/4M X 2-1/2L
  23. FITG REDUCER NPT1-1/4M NPT3/4F NYLON
  24. GREASE STRAINER
  25. 5G TANK
The image show the following components of the coolant refill system.
  1. Coolant concentrate tank
  2. Strainer
  3. Solenoid cable
  4. Filler hose
  5. Water solenoid cable
  6. Coolant concentrate solenoid cable
The coolant concentration in the coolant tank is incorrect. There is insufficient water pressure. Check the incoming water pressure.
The CRO is not calibrated. Calibrate the CRO.
The water supply or coolant concentrate solenoid does not receive voltage. Measure the voltage to the solenoids.
The water supply or coolant concentrate solenoid is contaminated and stays on. Clean the solenoids.
Thick concentrate, high viscosity. Install 1/2" nozzle on fill tube.
The CRO does not power on. The water supply or coolant concentrate solenoid does not receive voltage. Measure the voltage to the solenoids.
The coolant level sensor does not operate correctly. Troubleshoot the coolant level sensor.
The coolant tank overfills. The water supply or coolant concentrate solenoid is contaminated and stays on. Clean the solenoids.
Weak output flow to coolant refill  Orifice is too small in venturi valve causing weak flow.  Order new venturi valve 20-6616 with a larger orifice.
Coolant Concentration and Ratios
Make sure that the water supply has the correct pressure. The water supply must have a pressure of 40-100 psi (2.8-6.9 bar) to produce the desired coolant concentration.
Make sure the water supply screen [1] is not clogged. Clean the screen [1] if it is clogged. Make sure the cone side of the screen points toward the water supply. Make sure that the hose [2] is straight and does not have kinks.
If an aftermarket water filter is installed, make sure it is not clogged.
To correct the batch of coolant that is in the coolant tank, refer to the video Machine Tool Coolant - Top Up High Concentration - Video
The system may need to be calibrated to produce the correct coolant concentration. For calibration instructions, refer to Coolant Refill - Calibration.
Electrical Fault
Disconnect the cable from the CRO unit to the coolant connector bracket on the side of the machine.
For this section, complete all voltage measurements with the CRO unit commanded ON. On the Coolant Refill display, press [F3] to Add 5 gallons of coolant. Press [F3] again when you are ready to stop the CRO.
 Note: Use the notch [A] in the connector as a reference to find the correct pin.
Measure the voltage to the water supply solenoid [1]: The voltage across pins 2 and 5 of the connector on the coolant connector bracket must measure 120 VAC.
Measure the voltage to the coolant concentrate solenoid [2]: The voltage across pins 1 and 4 of the connector on the coolant connector bracket pulses on and off for 0.25 seconds each time it activates. Set your multimeter to Min/Max.
If the voltage is correct at the connector bracket:
  1. Connect the cable from the CRO to the coolant connector bracket.
  2. Shut off the water source.
  3. Measure for the voltage at the solenoid connectors [1 and 2]. They must measure 120 VAC. If there is no voltage at the solenoids, the solenoid cable from the CRO to the coolant connector bracket is at fault.
  4. If the voltage to the solenoids is correct, clean the solenoids. Go to Section 5.
If there is no voltage at the coolant connector bracket: Go to the applicable link below to troubleshoot the I/O PCB.
  • NGC I/O PCB Troubleshooting
  • CHC I/O PCB Troubleshooting
Solenoid Malfunction
Clean the solenoid: Remove the red cap [1]. Push the solenoid coil assembly [2] down to compress the split spring [4] inside.
Remove the specification plate [3]. Remove the split spring [4] and valve subassembly [5] from the coil assembly [2].
Disassemble the valve subassembly [5]. Clean the parts with compressed air. Be sure to remove all debris from inside the valve. Apply a thin coat of high-grade silicone grease to the body gasket [6].
1/2" Nozzle on Fill Tube
Electrical Diagram
