3 - Single-Stage Flood Coolant
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 3.1 Single-Stage Coolant - Overview
  • 3.2 Coolant Pump - Replacement
  • 3.3 Coolant Pump Impeller - Replacement
  • 3.4 Washdown Hose - Installation
  • 3.5 Coolant - Maintenance
  • 3.6 Single-Stage Coolant System - Troubleshooting
  • 3.7 Coolant Filter - Cast Aluminum Upgrade
Single-Stage Coolant Pump Identification
As of 02/21/2025, the coolant pump may arrive with different handles as shown on the right-hand side of the image. The older version is shown on the left. There is no functionality difference between the two styles of pump.
Improper Coolants
Coolant is an important part of many machining operations. When it is correctly used and maintained, coolant can improve part finish, lengthen tool life, and protect machine components from rust and other damage. Improper coolants, however, can cause significant damage to your machine.
Such damage can void your warranty, but it can also introduce hazardous conditions to your shop. For example, coolant leaks through damaged seals could create a slipping hazard.
Improper coolant use includes, but is not limited to, these points:
  • Do not use plain water. This causes machine components to rust.
  • Do not use flammable coolants.
  • Do not use straight or “neat” mineral-oil products. These products cause damage to rubber seals and tubing throughout the machine. If you use a minimum-quantity lubrication system for near-dry machining, use only the recommended oils.
Machine coolant must be water-soluble, synthetic oil-based or synthetic-based coolant or lubricant.
NOTE: Be sure to maintain your coolant mixture to keep the coolant concentrate at acceptable levels. Improperly maintained coolant mixtures can allow machine components to rust. Rust damage is not covered by your warranty.
Ask your HFO or your coolant dealer if you have questions about the specific coolant that you plan to use.
Coolant - Overview
3.2 Single-Stage Coolant Pump - Replacement
Single-Stage - Pump - 3/4 HP - Replacement
AD0217
Applies to machines built from: April, 1998
The 3/4 hp Single-Phase Universal Replacement Pump:
  • You can adapt this universal replacement pump to fit all machines that use a 3/4 hp single-phase pump.
  • The replacement pump fits and will operate the same as the old pump, although it may look different from the old pump.
  • Sheetmetal from your old pump will bolt onto the new unit.
  • If the power cable on the new pump is different from the old pump, move the cable from the old pump to the new pump.
Inspect the impeller before replacing entire pump assembly. Replacing a damaged impeller can correct noise and output issues. Refer to Standard (Flood) Coolant - System - Troubleshooting Guide for impeller replacement instructions.
Machine Compatibility
You can install the 3/4 hp, single-phase Universal Replacement Pump on any machine that currently has a 3/4 hp, single-phase coolant pump.
[A] 30-11848A QTY: 1 CLNT PUMP/MOTOR ASSEMBLY 3/4HP 1PH
[B] 26-7650A QTY: 1 PUMP IMPELLER
Tools Required
  • Wire Cutters
  • Crescent Wrench
  • Phillips Screwdriver
  • 3/16" Allen Wrench
  • Drill Bit - "Q" (0.322")
  • 1/8" NPT Tap and Handle
  • Drill
  • Thread Sealing Tape
Replacement
If a standard auxiliary coolant filter (AF-STD) system [1] is not connected to the old pump, do Step 2.
If a standard auxiliary coolant filter (AF-STD) system [1] is connected to your old pump, drill and tap a 1/8" NPT hole at the location on the pump shown.
Disconnect and remove the old pump [1] from the coolant tank.
Remove the hose fittings [3] from the old pump. Note their orientation and order.
Remove the old pump from the stand [2], if applicable.
Install the PUMP/MOTOR [A] into the old stand, if applicable. Use the old hardware.
Apply sealant to the threads of the old fittings [3]. Install the fittings [3] on the PUMP/MOTOR [A] in the correct location [4].
Connect the AF-STD fittings to the new pump, if applicable.
Do this step if you must replace the PUMP/MOTOR [A] and the plug on new cable [1] is not compatible with the machine:
Note the wiring before removing the cable. Remove the cable [1] from the old pump motor. Remove the cover and cable from the new PUMP/MOTOR [A]. Install the cable [1] from the old motor to the new PUMP/MOTOR [A].
Correctly connect the old cable to the new PUMP/MOTOR [A]. Use the (2) CRIMP WIRE NUTS [B]. Use wire strippers and crimp pliers to correctly connect the cable.
Install the new pump assembly into the coolant tank. Connect the supply hoses and power connector.
If you have an AF-STD system, install the 1/4" hose and the 1/8" to 1/4" fitting from the AF-STD kit into the hole you drilled in STEP 1.
Push COOLANT. Make sure the coolant system operates correctly. Examine all connections for leaks.
Single-Stage - A-Ryung Coolant Pump - Impeller - Replacement
AD0349
This procedure tells you how to install and shim a replacement impeller on an A-Ryung coolant pump.
Replacement
Put a mark [1] on the pump cover and the body so that you can install the cover in the correct orientation.
Remove these components:
  • The (3) screws [2] and the (3) lock washers [3] for the pump cover.
  • The impeller cover [4]
  • The Philip Head Screw (PHS) [5] and hard washer [6]
    Note: Turn the PHS [5] clockwise to loosen it. Discard the star washer if present where the hard washer [6] should be.
  • The impeller [7]
  • The shims from the impeller shaft [8]
Install the same number of shims that you removed onto the impeller shaft.
Install the impeller, the flat washer and the impeller screw.
Note: Turn the impeller screw counterclockwise to tighten it.
Adjust the number of shims on the impeller shaft until the gap between the impeller [1] and the pump base [2] is 0.007" [3].
Remove the impeller screw and flat washer.
Put red thread locking compound around the edge of the impeller shaft. [1]
Slide the impeller up and down on the shaft. Make sure that the locking compound is spread evenly on the shaft and the inside of the bore of the impeller.
Put red thread locking compound on the impeller screw [2].
Install the screw [2] and the flat washer [3].
Align the marks on the cover and the pump body.
Install the impeller cover with the (3) screws and (3) lock washers.
Washdown Hose - Installation - VMC
AD0104
Applies to machines built from: November, 2013
This procedure tells you how to install a washdown hose. The kit for the washdown hose is in the tote kit.
Mills larger than the VF-5 have a second washdown hose. To install a second washdown hose use this procedure: Supplemental Washdown Hose
These instructions apply to these machines:
  • VM-1/2 - Made after 11/13/2013
  • VF-1/2 - Made after 11/13/2013
  • VF-3/4/5 - Made after 02/20/2014
  • VF-6/7/8/9/10/11/12 - Made after 06/09/2014
  • DT-1 - Made after 06/09/2014
  • DM-1 - Made after 01/01/2015
  • MM/SMM - Made after 07/01/2015
Tools Required:
  • Crescent Wrench
  • 5/32" Allen Wrench
Apply thread sealant to all threaded surfaces of the coolant fittings.
Find the cap [1] at the bottom left on the enclosure. Remove the cap [1] from the MALE ENCLOSURE FITTING [2].
 Note: Coolant can come out when you remove the cap.
Attach the WASH GUN HOLSTER and GASKET [E] to the enclosure face. Use the screws [F].
NOTE: For proper operation, make sure the wash gun gasket is properly seated. It needs to be flush at the bottom of the wash gun housing.
Attach the HOSE ASSEMBLY [C] to the MALE ENCLOSURE FITTING [2]. Attach the HOSE ASSEMBLY [C] to the WASH GUN [D].
Put the HOSE ASSEMBLY [C] in the WASH GUN HOLSTER [E].
Coolant Tank – Maintaining Your Coolant Mixture
Machine Tool Coolant Series
We made these videos to address the most common questions and problems customers have about coolant maintenance. The videos are based on decades of day-to-day experience in our own factory machine shop, in our service department, and at our Haas Factory Outlets around the world.
Each video covers a complete topic, so you can watch them in any order, all together, or individually. If you are new to mixing and maintaining coolant, we recommend that you start with “Tools of Coolant”. This video gives you a complete overview of the tools you will need to make your coolant maintenance easier.
 Note: Be sure to maintain your coolant mixture to keep the coolant concentrate at acceptable levels. Improperly maintained coolant mixtures can allow machine components to rust. Rust damage is not covered by your warranty. Always wear proper eye protection when maintaining coolant systems. Clean any spilled coolant from the floor.
Machine Tool Coolant - Coolant Simplified
Machine Tool Coolant - Tools of Coolant
Machine Tool Coolant - Making a New Batch
Machine Tool Coolant - Top Up High Concentration
Machine Tool Coolant - Top Up Low Concentration
Machine Tool Coolant - Cleaning Your Tank
Looking for the maintenance log?
Coolant Maintenance Log
3.6 Single-Stage Coolant - Troubleshooting
Single Stage - Coolant Pump - Troubleshooting Guide - NGC
TG0138
Revision A - 12/2025
Download and fill out the coolant pump Inspection Report Checklist below before replacing any parts.
Coolant pump Inspection Report Checklist
The following service video shows how to troubleshoot a standard flood coolant pump
NOTE: This video is for reference only and does not replace the written procedure.
This troubleshooting guide applies to both 1-Phase and 3-Phase pumps.
In this image, the following components are shown.
  1. Coolant Pump Motor
  2. Coolant Outlet
  3. Pump Body
  4. Impeller Cap
  5. Impeller
NOTE: For troubleshooting information on the coolant float sensor, refer to the Coolant Level Float Sensor - Troubleshooting Guide for more information.
NOTE: Coolant Pumps with  PN: 30-14261 (1HP, 3-Phase without VFD) will follow the same installation process for non-VFD applications across all machines, with the exception of VF's VP-5, VM's, ST/DS, and UMC's.
ID0013 Coolant Pump Inspection Report Checklist requires the pump's serial number to be completed.
The serial number can be found on the side of the pump [1] in the box labeled serial number [2]
Machine with Variable Frequency Drive - The coolant takes too long to flow out the nozzles or Pcool. The variable frequency drive has an incorrect acceleration parameter value. Refer to the Coolant VFD - Troubleshooting Guide.
Noisy pump or cavitation Poor Coolant flow through enclosure Remove chip buildup.
Low Coolant Level Fill coolant tank.
Impeller contamination, or impeller damage Inspect impeller for damage or debris. Clean impeller or order kit 93-2609 to replace impeller. Follow Impeller Replacement Procedure to replace.
Motor bearing failure. Rotate the shaft by hand
Low coolant flow. Poor Coolant flow through enclosure Remove chip buildup.
Low coolant level in coolant tank Fill coolant tank.
Impeller contamination, or impeller damage Refer to the Coolant Pump Impeller Damage/Contamination section below to check the impeller in the pump.
Filter or pump intake blockage. Clean filter, check pump intake for blockage.
Pump intake or coolant output hose blockage Remove coolant check-valve and coolant output hose blockage.
Coolant nozzle blockage Remove blockage from coolant nozzles
The coolant pump is not building pressure. The motor shaft may be slipping due to the coupling not being fastened all the way. Thoroughly inspect the pump assembly and verify the motor shaft coupling is fastened down all the way.
No coolant flow and coolant circuit breaker did not trip. Setting 32 COOLANT OVERRIDE is set to IGNORE. Set Setting 32 COOLANT OVERRIDE to NORMAL.
Coolant pump motor does not receive voltage. See the No Voltage at the Pump Motor section below.
Incorrect power phasing - pump motor is running backward. Correct phasing
Impeller contamination or damage Refer to the Coolant Pump Impeller Damage/Contamination section below to check the impeller in the pump.
No coolant flow and the coolant circuit breaker tripped. Coolant pump motor short to ground. Measure coolant pump motor resistance to ground.
(Single-phase machines only), Alarm 552 TRIPPED CIRCUIT BREAKER occurs when the coolant pump gets commanded to turn on.
Note: The circuit breaker did not tripped.
The 240 VAC input cable connected to the PSUP at P11 is not correct. Verify the cable pinout for the cable that connects from the main circuit breaker to the PSUP at P11.  Refer to Incorrectly pinned power cable (Single-Phase) section.
Alarm 552 TRIPPED CIRCUIT BREAKER Refer to: Next Generation Control - Power Distribution PCB and PFDM - Troubleshooting Guide.
Coolant leaking from machine enclosure onto floor. This applies to ST-20 reboot enclosures only. The grommet that seals the Sub-Spindle Hydraulic Union drain line fails to seal due to the hose pulling on the grommet. Install the ST-20 Sub-Spindle Hose Routing Retrofit Kit Part Number: 93-3127. This reroutes the drain hose and clamps the hose limiting the movement and ability to pull on the grommet. Follow the Installation Guide to retrofit your machine.
Alarm 9823 Coolant VFD Fault
Alarm 9824 Shower Coolant VFD Fault
There is a problem with the Coolant / Shower VFD. Refer to the Coolant VFD - Troubleshooting Guide.
Coolant pump with an Aux filter is splashing on the floor when pump is commanded off When pump is commanded to stop coolant left over in the line returns through the pump and splashes into the tank.
Install a check valve on the output side of the aux filter to stop the coolant from returning and splashing. Please refer to Aux Filter Check Valve section for installation.
Please contact Haas Service if a check valve is installed to the output of the aux filter.
Motor hums when commanded to turn on
Note: For pumps dated DEC-2019 to FEB-2020
Coolant pump start capacitor failed.
Refer to the Coolant Pump - Start Capacitor - Replacement procedure.
Turns slowly, drawing higher than normal current and eventually trips the breaker
Turns backwards
Alarm 9823 COOLANT VFD FAULT The flood coolant pump has seized up. Refer to the Coolant Pump Impeller Damage/Contamination section below to check the impeller in the pump.
BREAKER
and
The CB3 on the PSUP PCB has tripped on machines without a VFD.
The 5/8" coolant hose leaks at the fittings or the hose pops off the fittings. The 5/8" Hose Clamp[1] PN: 59-1524 installed on the coolant hose is oversized and does not clamp the hose correctly. Replace the oversized hose clamp with PN: 59-2107 HOSE CLAMP EAR 20.1 - 23.3 MM. Use a Crimping Tool to secure the new hose clamp.
Poor coolant flow through enclosure
Remove all chips from the the auger trough [1], and the coolant return drain [2].
Remove chips from the coolant tank. Excessive chips in the coolant tank reduce the amount of coolant the tank can store. Watch the video Machine Tool Coolant - Cleaning Your Tank - Video.
Fill the coolant tank. Watch the video Standard Coolant – Simplified - Filling your Tank … and More.
Make sure the coolant level sensor operates correctly.
Remove the impeller cap [1] from the bottom of the pump. Remove the screw that connects the impeller [2] to the shaft. Steel impellers have left-hand threads [3].
Carefully remove and clean the impeller [2]. Check for wear, damage, or cracking of the impeller [2].
If the impeller is damaged or cracked, order a replacement impeller, service part 93-2609. Follow Impeller Replacement Procedure to replace.
Rotate the coolant pump shaft by hand. If the shaft does not turn freely, the motor bearings are damaged.
Install the impeller [2]. Rotate the coolant pump shaft by hand, and make sure the impeller does not rub on the pump body [4]. If the impeller rubs against the pump body, install shims between the impeller [2] and the coolant pump shaft. Install the impeller cap [1]. If the impeller [2] rubs against the impeller cap [1], remove one shim at a time until it does not rub.
There are several filters that keep chips out of the coolant pump. Refer to Section 3 for filter maintenance information.
Aux Filter Check Valve Install
Place the check valve [1] on the outlet side of the auxiliary filter as shown.
NOTE: Please contact Haas Service if this is done.
Filter or pump blockage
Clean or replace the filter element. Check the area around the coolant pump intake for chips.
  1. Auxiliary Filter - The bag filters in Auxiliary Filter tanks need to be cleaned or replaced. The Auxiliary Filter is an option. Your machine might not have this option.
  2. Standard Filter - Standard Filters need to be cleaned.
Disconnect both ends of the coolant hoses. Remove any kinks. In the opposite direction of the coolant flow, blow air through the hoses to remove any chips. If you find chips in the hoses, check the coolant nozzles and washdown hoses for chip buildup. Connect the coolant hoses.
Remove chips from the basket filter in the coolant tank. For maintenance instructions, refer to the Coolant Tank ‑ Maintenance procedure.
Check valve blockage (Coolant filter and Haas Chip Seperator)
Remove the coolant check-valve. Check it for blockage [1]. Make sure the trap door opens and closes freely. If the trap door does not close, coolant flows back into the tank. This delays the flow of coolant by a few seconds.
Remove and clean the coolant nozzles.
Cycle the pump power to flush the coolant lines.
Make sure the coolant tank is free of chips and contamination.
Defective pump
  1. Disconnect the pump cable from the machine.
  2. With a ohm-meter measure each leg tab to the ground tab.
     Note: The ground tab has a bent. The example shown is a 3-phase pump with 4 tabs (L1, L2, L3 + Ground), single phase pumps have 3 tabs (L1, L2 + Ground).
    • If all the legs test open (O.L) to the ground tab then the pump and cable do not have a short circuit, see the next section.
    • If the motor cable leads [3] indicate a short, remove the motor cable cover and disconnect the cable from the motor.
  3. Measure the motor cable leads [5] to ground [6] terminal screw or chassis. If any lead tests short, the pump is at fault. If none of the leads [5] test short, the cable is at fault.
  4. If all the leads test OK, check the coolant pump for binding that could cause an over amperage condition.
No voltage at pump motor
  1. First inspect the pump motor for a short circuit see section Defective Pump.
  2. Make sure the coolant pump cable is connected to the machine.
     Important: Do not disconnect the coolant pump from the machine, doing this test without a load will give you false readings.
  3. Remove the pump motor cover and locate the white, black, red wires for 3-phase motor or white and black for a single-phase.
  4. Verify that coolant circuit breaker is set to on and setting 32 COOLANT OVERRIDE is set to NORMAL.
  5. Press the [COOLANT] button to turn on the coolant pump.
  6. Measure the voltage at the motor from lead to lead [1]. The reading must be 240 VAC. The motor shown is a 3-phase motor.
    • If you read 240 VAC, the coolant pump motor is damaged.
    • If you do not read 240 VAC, check at the I/O PCB coolant output. If there is still no voltage check the 240 VAC source from the PSUP PCB to I/O PCB.
Incorrect phasing
The power supply PCB has a phase detect with neon indicators on the top center portion of the board. Make sure that the electrical power is phased correctly:
  • Green Light: The incoming power is phased correctly.
  • Orange Light: The incoming power is incorrectly phased.
  • Both Lights: A phase is missing (there is a loose cable in the system).
If the electrical power is phased incorrectly:
Set the main circuit breaker to the OFF position.
Swap the #74 and #75 incoming power cables at the main transformer.
Correct the pinnout on cable P/N 33-0197C, PSUP P11 (NGC).
The cable should match the drawing shown.
Coolant Hose Clamp Failure
Problem: The 5/8" coolant hose leaks at the fittings or the hose pops off the fittings.
Cause: The 5/8" Hose Clamp[1] PN: 59-1524 installed on the coolant hose is oversized and does not clamp the hose correctly.
Solution: Replace the oversized hose clamp with PN: 59-2107 HOSE CLAMP EAR 20.1 - 23.3 MM. Use a Crimping Tool to secure the new hose clamp.
Electrical Diagrams
Use this electrical diagram for coolant pumps that are being driven by the I/O PCB.
Coolant Filter - Cast-Aluminum - Upgrade
AD0246
Machines built after December 2015 have the cast coolant-filter [1]. This procedure tells you how to replace the standard coolant-filter [2] with the cast coolant-filter [1]. The standard coolant-filter [2] has a plastic reservoir.
 Note: The cast coolant-filter [1] replaces all standard coolant-filters [2].
Note: The coolant filter has been replaced with the chip seperator. For more information regarding the chip seperator click here.
The cast coolant-filter is compatible with VMCs and HMCs.
93-2356 QTY: 1
FILTER, STANDARD COOLANT HEAD/BOWL REPLACEMENT KIT
Standard Coolant Filter Assembly - Replacement
For DM, DT, EC-1600, MM, SMM, and TM machines: Use the (2) crescent wrenches and remove the 1/2" fitting [2]. Use the allen wrench to install the plug [3].
For DM, DT, MM, SMM, and TM machines: Use the (2) crescent wrenches to remove the 5/8" fitting [1] and install the 1/2" fitting [2].
For all machines, go to step 2.
Remove all coolant hoses. Use the (2) crescent wrenches to remove all fittings [3] and the valve assembly [1]. Keep all the fittings. Remove and discard the standard coolant-filter [2].
Attach the cast coolant-filter [5]. Use the Phillips screwdriver and install the (2) screws [6]. Install all coolant fittings [3] and the valve assembly [1].
Connect the hose [4].
When you install the (3) remaining hoses, do these steps for each hose:
  • Install the hose cap [7].
  • Install the hose clamp [8].
  • Use the crimp pliers [9] to crimp the hose clamp [8].
If the machine has 3/4" coolant hoses, use the 1/2"-to-3/4" inch adapter in the kit.
