23 - Chip Tray Strainer
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 23.1 Chip Tray Strainer Kit
  • 23.2 Chip Tray Filter Replacement
Chip Tray Strainer Kit - Installation
AD0099
Revision C - 2/2026
Updated
This procedure tells you how to install the coolant chip tray strainer. This filter removes very small particles (200-micron) from the coolant.
Machine Requirements:
  • Machines manufactured after 11/2011 with a 20-, 48-, 55-, or 95- gallon coolant tank.
Applicable service kits:
Required for machines built from 11/2011 - 10/27/2025:
 NOTE: The following service kits apply to machines built during this period:
  • 93-1001249 CHIP TRAY AND CLNT TANK FIELD INSTALL KIT
  • 93-1001014 SUPPLEMENTAL CHIP TRAY FIELD INSTALL KIT
Required for machines built after 10/27/2025:
The following kits are used to replace the chip tray and/or strainer: These kits are not compatible with the previous strainer kit.
  • 93-1001245 CHIP TRAY FIELD INSTALL KIT
  • 93-1001240 SUPPLEMENTAL CHIP TRAY FIELD INSTALL KIT
NOTE: As of 10/27/2025, only kit part numbers 93-1001245 and 93-1001240 are supported.
After this date, only Step 1 of this installation procedure is applicable.
Insert the chip tray filter screen 93-1001240 [1] into the coolant tank chip tray 93-1001245 [2].
Place the chip tray assembly into the coolant tank [3].
NOTE: The fitment for the new chip tray and strainer is the same as the previous iteration.
For service kits acquired between 11/2011 and 10/27/2025.
  • 93-1001249 CHIP TRAY AND CLNT TANK FIELD INSTALL KIT (1)
  • 93-1001014 SUPPLEMENTAL CHIP TRAY FIELD INSTALL KIT (2)
Put the strainer [A] across the top and around the sides of the wire basket [B].
Put the wire basket [B] into the clean chip tray [1].
Install the assembly [2] into the coolant tank.
AD0296
Applies to machines built from: January, 2007
Parts Required
[KIT]   93-30-10904  QTY: 1
FILTER, SUPPLEMENTAL CHIP TRAY FILTER BASKET X10
Always wear proper eye protection and gloves when performing coolant tank maintenance.
Remove the chip basket and polyester mesh strainer (if the strainer is installed) from the chip tray. Remove all chips from the chip strainer basket.
To replace the mesh strainer, pull the mesh strainer [1] tightly over the top of the chip basket [3]. Make sure the elastic band [2] touches the outside and is below the edge of the basket [3].
Put the chip basket and attached mesh strainer in the chip tray.
Gate Filter Maintenance
Remove the gate filter [1] if it is installed. Clean the filter screen. Use a soft brush and a solution of warm water and soap.
Flush the filter with warm water.
Install the gate filter [2] if you have one.
Clean any spilled coolant from the floor.
Monitor the chip tray during operation. If necessary, adjust the maintenance schedule.
Examine the coolant level at 8-hour intervals of machine operation. Fill the tank again as necessary.
