2 - Auxiliary Coolant Filter
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 2.1 Auxiliary Coolant Filter - Installation
  • 2.2 Auxiliary Coolant Filter - Maintenance
AD0111
Revision A - 10/2025
This procedure tells you how to install an auxiliary coolant filter (AF) system. This #2 bag-type filter system removes contamination and small particles from the coolant before they go through the coolant pump again.
This procedure tells you how to connect the AF to these coolant systems:
  • Single Stage Coolant Pump
  • Through-Spindle Coolant (TSC) Option
  • High pressure coolant (HPC) Option
 Note: Do not connect the Auxilary Filter system to a Multistage Coolant Pump .
 Note:  Do not connect the Auxilary Filter system to a High-Pressure Flood Coolant (HPFC) pump.
Machine Compatibility:
  • All machines excluding TM and TL's.
This document applies to the following service kit:
  • 93-1000284 AUXILIARY FILTER KIT
Prerequisites:
Do not apply thread sealant to the hose connections. This makes the hose difficult to remove.
 Note: The illustrations in this procedure show the installed configuration.
Single Stage Coolant Pump - Installation
If the machine has a single stage coolant pump:
  • Disconnect the coolant supply hose [1], from the pump outlet [2].
  • Connect the lower supply hose [3] to the coolant supply hose [1].
  • Connect the upper AF hose [4] to the coolant pump outlet [2].
  • Close the machine doors and windows.
 Note: Coolant can splash in the machine.
  • Start the coolant pump.
  • While the coolant pump is on, open the AF lid.
 Note: This pushes the air out of the AF.
  • Close the lid when the AF is full.
HPC/TSC-300 Without Auto Clean - Installation
HPC/TSC 300 pump without the Auto Clean pump.
  • Remove the coolant return loop [1].
  • Install the coolant hose adapter [A] to the 3/4" NPT port.
  • Connect the upper AF hose [2] to the coolant hose adapter.
  • Connect the 12" (30 cm) pump hose [B] to the 1/2" NPT port in the pump stand.
  • Attach the lower AF hose [3] to the 12" (30 cm) hose [B].
  • Remove the AF lid while the coolant pump is on.
  • Use the wash gun to fill the AF with the coolant.
    Note: Be careful Coolant can splash at you when using the wash gun.
  • Install the lid when the AF is full.
HPC/TSC-300/1K with Auto Clean - Installation
HPC/TSC 300 pump with the Auto Clean pump.
  • Connect the lower AF hose [3] to the swivel fitting on the outlet pipe.
  • Connect the upper AF hose [2] to the stand pipe [4].
     Note: Becareful Coolant can splash at you when using the wash gun.
Verification
Operate the standard coolant pump for (5) minutes. Check for leaks.
For maintenance information, refer to Auxiliary Filter - Bag Filter - Replacement.
Auxiliary Coolant - Maintenance
Replace the Filter on Your Aux Coolant system.
Filter Replacement Auxilary Coolant Filter System w/Pressure Gauge.
Filter Replacement Auxilary Coolant Filter System without/Pressure Gauge
