      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
20 - Chip Separator
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Standard Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - UMC
  • 9 - Chip Conveyor - Lathe
  • 10 - Coolant Refill
  • 11 - High Pressure Flood Coolant
  • 12 - Through-Spindle Coolant
  • 13 - Through-Tool Air Blast
  • 14 - Haas Chip Lift
  • 15 - Mist Condenser
  • 16 - Coolant Level Float Sensor
  • 17 - Mini Conveyor
  • 18 - Coolant VFD
  • 19 - Coolant Sanitizer
  • 20 - Chip Separator
  • 21 - Chip Tray Strainer
  • 20.1 Chip Separator - Installation
  • 20.2 Chip Separator - Maintenance
  • 20.3 Chip Separator - Filter Element Replacement
AD0782
This procedure will show you how to install a Chip separator on your machine
This procedure applies to the following kits :
  • 93-2356 CLNT FILTER ASSY SERVICE KIT
  • 93-2876  FIELD INSTALL KIT CPK-MM EDU/UK
Machine compatibility
  • All HMCs and VMCs
Note : Chip separator is an updated coolant filter unit. For more information regarding the coolant filter click here.
Important : Make sure to depressurize the coolant system using the washgun after turning off the machine.
Remove the coolant hoses connected to the Coolant Filter [2] then remove from the enclosure.
Note : The hose clamps are crimped and need to be replaced after removal.
Install chip separator assembly using the provided hardware onto the machine.
Connect coolant pump to fitting [1].
Connect spindle flood coolant to fitting [2].
Fittings [3] and [4] are for washguns.
Important : Valve [5] is for maintenance and should be opened to evacuate built up chips periodically.
Important : TSC option does not connect to the chip seperator or coolant filter.
To properly connect the coolant hoses slip the hose clamp [2] on the hose then place a hose cap [3] on the fitting before joining both together. Crimp the hose clamp using a crimping tool [1] and give the hose a slight tug to ensure proper clamping.
Note : Ensure that the rounded edge of the hose cap [3]  is facing away from the hose.
Turn on the machine and verify that the system is leak free. Inspect the pressure gauge to verify that the pressure is 25-30 psi.
This procedure will show you how to properly maintain your chip seperator.
Proper maintenance ensures that the coolant is flowing cleanly and efficiently. We reccomend to periodically check the pressure gauge and perform the maintenance steps listed below.
Internal Components
  1. Top cap
  2. Sealing O-ring
  3. Filtering mesh element
  4. Silicone gasket
Flow Direction
Coolant flow from coolant pump into fitting [1] and the heavy metal chips collect at the bottom of the housing [3] after being filtered out by the mesh element [4].
Debris and metal chip free coolant [2] is then pumped and distributed to machine components through the top fitting [5].
Note : Pressure gauge should be reading between 25 and 30 psi.
Check for PSI drop of 5 PSI or more on gauge [1] to determine if the chip separator needs to be emptied or not.
Note : Coolant flow is affected if chip separator is not regularly maintained.
Note : Make sure that the coolant pump are off and that the machine is powered down. Verify that there is no pressure in the coolant system by reading the pressure gauge.
Open ball valve to release all metal chips and debris into a container to be disposed of properly.
20.3 Chip separator Filter Element Replacement
AD0818
This procedure will show you how to replace the filter in your chip separator.
This Document Applies to the following Service Kits:
  • 93-4865 CHIP SEPARATOR SERVICE KIT (Available on 12/24)
Required tools :
  • 3/16" Hex bit
  • Torque Wrench
  • Silicone grease
Machine Compatibility :
  • All VMCs and HMCs
Note : It is recommended to use the Haas Fastener Torque Specifications
Replacement
Press [POWER OFF] to power down the machine and inspect the pressure gauge [1] to ensure that the pressure reading is at 0 psi.
Open the ball valve [1] at the bottom of the chip separator to release all metal chips and debris into a container below to be disposed of properly.
Remove the (8) 1/4-20 bolts [1] from the top cap [2] to access the filter element.
Note : The hoses can stay attached to the top manifold and placed to the side.
Remove and replace the following components :
  • Sealing o-ring [1]
  • Filtering mesh element [2]
  • Silicone gasket [3]
Note : Clean the inside of the filter housing before installing the replacement components.
Note : Lubricate the sealing o-ring [1] with a light coat of silicone grease to prevent excessive friction during re-assembly.
Re-install the top cap and torque in a star pattern for even clamping.
Note : Some components are hidden in this illustration for clarity purposes.
