14 - Through-Spindle Coolant
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Single-Stage Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - Overview
  • 8a - Standard Belt Chip Conveyor
  • 8c - CDF Chip Conveyor
  • 9 - Chip Conveyor - VMC
  • 10 - Chip Conveyor - UMC
  • 11 - Chip Conveyor - Lathe
  • 12 - Coolant Refill
  • 13 - High Pressure Flood Coolant
  • 14 - Through-Spindle Coolant
  • 15 - Through-Tool Air Blast
  • 15a - Through-Tool Oil Mist
  • 16 - Haas Chip Lift
  • 17 - Mist Condenser
  • 18 - Coolant Level Float Sensor
  • 19 - Mini Conveyor
  • 20 - Coolant VFD
  • 21 - Coolant Sanitizer
  • 22 - Chip Separator
  • 23 - Chip Tray Strainer
  • 24 - Multi-Stage Flood Coolant
  • 25 - Coolant Cart
  • 14.1 TSC - Overview
  • 14.2 TSC - Service Replacements
  • 14.3 TSC - Troubleshooting
14.1 TSC - Overview
TSC - Overview
40-Taper - TSC - Union Replacement
Procedure Description
40-Taper - Inline - Compensating TSC Union - Replacement - VMC - AD0377 This procedure will show you how to replace the compensating TSC union on a VMC 40-Taper - Inline Spindle.
40-Taper - Inline - Compensating TSC Union - Retrofit - AD0391 This procedure will show you how to retrofit a Compensating union from a bearingless union.
Compensating TSC Union Seal - Replacement - AD0495 This procedure will show you how to replace the piston cup seal and piston o-ring on all compensating (springless) TSC union assemblies. Replace the seals if you know or suspect them to be worn, torn, or damaged.
50-Taper - TSC - Union Replacement
50 Taper - TSC - Compensating Union and Threadless Transfer Tube - Replacement - Mill - AD0412 This procedure explains how to replace the compensating coolant union and the threadless transfer tube  on the vertical 50 taper mill built after August 2018.
Download and fill out the coolant pump Inspection Report Checklist below before replacing any parts.
Coolant pump Inspection Report Checklist
TSC - Troubleshooting Guides
Troubleshooting Guide Description
TSC-300/1K - Troubleshooting Guide - NGC This troubleshooting guide will help you troubleshoot problems with the TSC-300 and TSC-1k system.
