Lathe - Non-Contact Encoder - Replacement - AD0357
Service Home How To Procedures Lathe - Non-Contact Encoder - Replacement - AD0357
- Jump to Section - 1. Introduction 2. Parts Included 3. Replacement (5 steps) 4. Lathe Encoder Ring to Read Head Alignment 5. Verification (1 step) Back to Top
Recently Updated Last updated: 07/30/2025
AD0357
Version A - 07/2025
This procedure tells you how to replace the non-contact encoder (NCE) on the lathe spindle. The replacement encoder may be from a different manufacturer than the encoder you are replacing. The installation and operation are the same.
 CAUTION: Always replace the encoder ring and the read head as a set. Gen 1 and Gen 2 NCEs will not communicate with each other’s components. A replacement with a Gen 2 NCE requires a full replacement for the read head and ring.
 NOTE: Gen 2 NCEs will have "Gen 2" printed both on top of the read head and on the side of the ring. Gen 1 NCEs do not have any print indicating that its Gen 1.
 IMPORTANT: When replacing a non-contact encoder under warranty, make sure the old part is returned in the replacement part packaging, or the warranty may be voided.
Parts Included
This procedure applies to the following service kits :
  • 93-2632 NCE 5.6" LATHE SERVICE KIT
Replacement
Remove the coolant collector shroud, the door, the left front enclosure panel, and the left rear enclosure panel.
 NOTE: If the machine has an Automatic Tool Probe (ATP), disconnect the tool probe cable at the control cabinet. Remove the air cylinder from the tool probe. This makes it easier to access the (2) tool probe air hoses. Disconnect the air hoses and push them through the hole in the lower left front enclosure panel. Remove the panel.
Remove the chuck and the hydraulic union. Make sure to plug the (2) hydraulic hoses.
Determine Encoder Ring Orientation:
The ST-10 spindles built from late October 2016 to Early February 2017 mount the encoder ring to the adapter plate with the orientation mark facing the machined step face of the adapter plate [1]. The encoder orientation marks on the ring and the read head must both be facing the same direction [1].
ST-10 spindles built after early February 2017 mount the encoder ring on the pulley and have the orientation marks exposed [2].
ST-15 spindles are the same orientation as the latest ST-10, with the ring mounted to the pulley and the orientation marks facing away from the machined face[3].
Temporarily remove the read-head[2] and cable[3]. Secure the read-head out of the way to the motor mount brace with a cable tie.
If loose fit: loosen screws and carefully remove the ring without causing damage to the outer ring shield.
If sweat fit: remove the screws from the through holes, install the screws to the threaded hole pattern and use them as jacking screws to evenly remove the encoder ring.
Use a stone to smooth out the marks left from the jacking screws when you're done.
Install the Non-Contact Encoder.
If the ring is slip fit, install, and indicate it to .0005" TIR. If the ring is sweat fit, it may mount directly to the spindle bearing lock or it may mount to an encoder ring mount that mounts to the pulley.
Heat the encoder ring on a hot plate to a max temperature of 248 °F (120 °C). Install to the ring mount, press evenly to seat it square into the shoulder
NOTE: Make sure the printing on the ring faces out. Make sure the label "►|◄" on the ring is aligned underneath the arrow on the read head.
Tighten the (6) encoder ring screws by hand.
Once the ring has cooled down check the outer diameter runout NTE 0.0005" TIR. Mark the high point. This location is where the read head will be shimmed.
 CAUTION: Never use a tool to strike the ring. Damage to the magnetic band will result.
Torque the (6) encoder ring screws to 30 in-lbs.
Install NCE read head[1] being sure to use (2) WASHER FLAT 0.170ID X 0.400OD before installing read head mounting screws.
 IMPORTANT: Gen 2 NCE read heads do not use any 45-2000 washers. Remove these washers if they were present underneath the Gen 1 NCE read head.
Use the plastic shim [3] provided with the NCE to set the gap between the read head and the NCE ring[2] by pushing the read head evenly onto shim/ring at the marked high point[4].
NOTE: The running gap dimension set by the shim can be found in the Spindle Encoder - Troubleshooting Guide - NGC.
Remove the shim. You should feel a slight drag on the shim as you remove it. Torque read head screw to 25 in-lbs once correct spacing is achieved.
Connect the encoder cable.
Proper alignment of the read head to the encoder ring is critical. The alignment will vary based on the brand of encoder. Use the chart provided to make sure the encoder ring and read head are properly aligned.
        VENDOR                                 RLS
               A                    0.0118" +0.0079 / -0.0039
               B                       0.0591" +0.059 / -0.019
               C                                    (0.0197")
IMPORTANT: If C for RLS 2" or 3" NCE is over 0.0197" you will need to order a new NCE read head mount:
If machine currently uses 20-7328A NCE READ HEAD SPACER, TL, then order:
  • 20-7328C SPACER READ HEAD NCE 2" GEN 2 TL
If machine currently uses 20-7669 NCE READ HEAD MOUNT, ST-40/50 GBOX, then order:
  • 20-7669A NCE READ HEAD MOUNT ST-40/45 GBOX GEN 2
NOTE: For ST-15/20/28/30/35 machines, see ST-15/20/28/30/35 - Non-Contact Encoder Ring - Replacement
        VENDOR                                 BAUMER
               A                                0.0118" +/-0.004
               B                                 0.045" +/-0.019
               C                                        (0.305")
Verification
Once machine is re-assembled:
Operate the spindle at 25%, 50%, and 100% of the maximum speed.
Make sure the spindle speed in the code is the same as the spindle speed on the display.
If these spindle speeds are not the same, make sure the encoder parameters are correct.
 NOTE: Encoders manufactured by RLS and AMC use the same parameters.
