DT/DM - Double Arm - Replacement - AD0211
Service Home How To Procedures DT/DM - Double Arm - Replacement
AD0211
- Jump to Section - 1. Introduction 2. Double Arm - Removal (4 steps) 3. Double Arm - Installation and Alignment Back to Top
This procedure will show you how to replace and align the DT/DM double arm.
Tools Required:
  • T-2108 Double Arm Alignment Tool
  • (2) 3/8-16 x 2.5" Socket-Head Cap Screws (SHCS)
  • DT:
    • T-1224 BT 30 Taper Split Tool
    • T-2173 BT 30 Taper Split Tool Pin
  • DM:
    • T-2086 CT 40 Taper Split Tool
    • T-2087 BT 40 Taper Split Tool
This document applies to the following service kits:
  • 93-30-4448 DBL ARM ASSY DT-1 SMTC BT-30 8"
Make sure no tool [1] is in the active tool pocket and the spindle.
Move the center of the table under the spindle.
Push EMERGENCY STOP.
Change Parameter 462:18, INVIS AXIS, to 0.
Change Parameter 390:18, INVIS AXIS, to 0.
Find the (2) holes [1] adjacent to the covers for the plungers.
If the arm does not have the holes, go to step 3. If the double arm has the holes, do these steps:
  • Insert the (2) 1/4-20 x 2.5" screws [4] through the T-2108 tool [2] and into the double arm.
  • Tighten the (2) screws.
  • Tighten the 3/8-16 x 1.75" screw [3] by hand
Release EMERGENCY STOP.
Push RESET to clear each alarm.
Jog the T Axis (Tool Changer Arm) in the negative (-) direction. Do this until it is at the bottom of its travel.
Remove (2) of the (4) 3/8-16 x 3/4" screws [1] from opposite sides of the hub. Do not remove adjacent screws.
NOTE: Be careful not to damage the output shaft.
Install (2) 3/8-16 x 2.5" jack screws [2] into the hub.
Loosen the (6) screws [3] from the clamp for the double arm. Then loosen them 3 more turns.
Tighten the (2) jack screws [1] in small increments.
Do this until the double arm can turn freely on the output shaft.
Tighten the jack screws one more full turn.
Loosen the center screw [2] on the alignment tool.
Remove the double arm.
Remove the (2) 3/8-16 x 2.5" jack screws.
Re-install the (2) 3/8-16 x 3/4" screws to retain the hub. Torque the screws to 45 ft-lb (61 N-m).
DT/DM Tool Changer - Alingment Procedure
