4+1 Pallet Pool, EC-1600ZT (PALLET POOL-HMC-LG-4)
Product Image
GET QUOTE
4+1 Pallet Pool for the EC-1600ZT
    CNY ONLY
Automated loading for big parts
  • Max part size: 55" diameter x 54" tall  (1397 mm dia. x 1372 mm)
  • 4+1 pallets (4 storage + 1 machining station)
  • 5000 lb (2268 kg) max per pallet
  • Multi-zone light curtain for safety
  • Fully integrated solution
  • Easy-to-use scheduling interface
  • Dedicated load/unload station
  • Must be ordered with the machine
  • 4+1 Stations
  • 32" x 32" Pallet Size
  • Option Info
  • Specs
OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 4+1 pallet pool for the Haas EC-1600ZT HMC is the perfect solution for automated loading and unattended machining of large, heavy parts. It's also well suited for low-volume repeat jobs, where you want to keep the fixturing intact between runs.
The pallets are 32" x 32" (813 x 813 mm), and can support up to 5000 lb (2268 kg). There are 4 storage locations and 1 machining station, and pallets can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading. Includes the built-in 4th-Axis Rotary Platter option and CNC Control Cabinet Cooler.
NOTE: Requires 70+1 side-mount tool changer. Not available for field installation.
  • Layout Drawing
  • Installation Guide
Haas EC-1600ZT
EC-1600ZT
CNC Horizontal Mill with 64" x 50" x 40" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
OTHER PALLET POOLS
Product Image
3+1 Pallet Pool, VF-2YT Series
High-volume production, unattended operation
  • 3+1 Stations
  • 36" x 18" Pallet Size
    CNY ONLY
Product Image
6+1 Pallet Pool, VF-2YT Series
  • 6+1 Stations
    CNY ONLY
Product Image
5+1 Pallet Pool for VF-4 Series
  • 5+1 Stations
  • 52" x 20" Pallet Size
    CNY ONLY
Product Image
6+1 Pallet Pool, UMC-1250/SS
  • 6+1 Stations
  • 22" x 22" Pallet Size
    CNY ONLY
Product Image
20+1 Pallet Pool, UMC-500/SS
  • 20+1 Stations
  • 8" x 8" Pallet Size
    CNY ONLY
Product Image
10+1 Pallet Pool, UMC
  • 10+1 Stations
  • 15.75" x 11.75" Pallet Size
    CNY ONLY
Product Image
6+1 Pallet Pool, VC-400/SS
  • 6+1 Stations
  • 22" x 14.5" Pallet Size
    CNY ONLY
Product Image
6+1 Pallet Pool, EC-400
  • 6+1 Stations
  • 400 mm Pallet Size
    CNY ONLY
Pallet Changer S.A.E METRIC
Number of Stations 4 + 1 4 + 1
Pallet Quantity 5 5
Pallet Length 32.00 in 813 mm
Pallet Width 32.00 in 813 mm
Max Pallet Load 5000 lb 2268.0 kg
Max Part Diameter 55.0 in 1397 mm
Max Part Height (workholding + workpiece) 54.0 in 1,372 mm
Pallet Change Time 120 s 120 s
Pallet Clamp Force 45,000 lbf 200,170 N
Crate for Sheet Metal 102.0 in x 71.5 in x 56.0 in 259 cm x 182 cm x 142 cm
Crate for Pallets, EC-1600ZT PP 110.0 in x 74.0 in x 19.0 in 279 cm x 188 cm x 48 cm
Crate for Bases, EC-1600ZT PP 177.0 in x 124.5 in x 52.0 in 450 cm x 316 cm x 132 cm
Crate for Load Station/Ctr Table, EC-1600ZT PP 194.0 in x 120.0 in x 58.0 in 493 cm x 305 cm x 147 cm
Need More Information?
