Lathe - Settings
Lathe - Settings
Setting Number Description
1 Auto Power Off Timer
2 Power Off at M30
4 Graphics Rapid Path
5 Graphics Drill Point
6 Front Panel Lock
8 Prog Memory Lock
9 Dimensioning
10 Limit Rapid at 50%
17 Opt Stop Lock Out
18 Block Delete Lock Out
19 Feedrate Override Lock
20 Spindle Override Lock
21 Rapid Override Lock
22 Can Cycle Delta Z
23 9xxx Progs Edit Lock
28 Can Cycle Act w/o X/Y
29 G91 Non-modal
31 Reset Program Pointer
32 Coolant Override
39 Beep @ M00, M01, M02, M30
42 M00 After Tool Change
43 Cutter Comp Type
44 Min F Radius CC%
45 Mirror Image X Axis
46 Mirror Image Y Axis
47 Mirror Image Z Axis
52 G83 Retract Above R
53 Jog w/o Zero Return
56 M30 Restore Default G
57 Exact Stop Canned X-Y
58 Cutter Compensation
59 Probe Offset X+
60 Probe Offset X-
63 Tool Probe Width
64 Tool Offset Measure Uses Work
71 Default G51 Scaling
72 Default G68 Rotation
73 G68 Incremental Angle
74 9xxx Progs Trace
75 9xxx Progs Single BLK
77 Scale Integer F
80 Mirror Image B Axis
82 Language
83 M30/Resets Overrides
84 Tool Overload Action
85 Maximum Corner Rounding
87 Tool Change Resets Override
88 Reset Resets Override
90 Max Tools To Display
93 Tailstock X Clearance
94 Tailstock Z Clearance
95 Thread Chamfer Size
96 Thread Chamfer Angle
97 Tool Change Direction
99 Thread Minimum Cut
101 Feed Override -> Rapid
102 C Axis Diameter
103 Cyc Start/Fh Same Key
104 Jog Handle to SNGL BLK
105 TailStock Retract Distance
108 Quick Rotary G28
109 Warm-Up Time in Min.
110 Warmup X Distance
111 Warmup Y Distance
112 Warmup Z Distance
113 Tool Change Method
114 Conveyor Cycle Time (minutes)
115 Conveyor On-Time (minutes)
117 G143 Global Offset
118 M99 Bumps M30 Cntrs
119 Offset Lock
120 Macro Var Lock
130 Tap Retract Speed
131 Auto Door
133 Repeat Rigid Tap
142 Offset Chng Tolerance
143 Machine Data Collection Port
144 Feed Override -> Spindle
145 Tailstock At Part For Cycle Start
155 Load Pocket Tables
156 Save Offsets with Program
158 X Screw Thermal Comp%
159 Y Screw Thermal Comp%
160 Z Screw Thermal Comp%
162 Default To Float
163 Disable .1 Jog Rate
165 Ssv Variation (RPM)
166 Ssv Cycle
191 Default Smoothness
196 Conveyor Shutoff
197 Coolant Shutoff
199 Backlight Timer
216 Servo and Hydraulic Shutoff
232 G76 Default P Code
238 High Intensity Light Timer (minutes)
239 Worklight Off Timer (minutes)
240 Tool Life Warning
241 Tailstock Hold Force
242 Air Water Purge Interval
243 Air Water Purge On-Time
245 Hazardous Vibration Sensitivity
247 Simultaneous XYZ Motion in Tool Change
249 Enable Haas Startup Screen
250 Mirror Image C Axis
251 Subprogram Search Location
252 Custom Subprogram Search Location
253 Default Graphics Tool Width
261 DPRNT Store Location
262 DPRNT Destination File Path
263 DPRNT Port
264 Autofeed Step Up
265 Autofeed Step Down
266 Autofeed Minimum Override
267 Exit Jog Mode After Idle TIme
268 Second Home Position X
269 Second Home Position Y
270 Second Home Position Z
276 Workholding Input Monitor
277 Lubrication Cycle Interval
281 Chuck Foot Pedal Lock Out
282 Main Spindle Chuck Clamping
283 Chuck Unclamp RPM
284 Cycle Start Allowed With Chuck Unclamped
285 X Diameter Programming
286 Canned Cycle Cut Depth
287 Canned Cycle Retraction
289 Thread Finish Allowance
291 Main Spindle Speed Limit
292 Door Open Spindle Speed Limit
306 Minimum Chip Clear Time
313 Max User Tavel Limit X
314 Max User Travel Limit Y
315 Max User Travel Limit Z
319 VDI Spindle Center Line X
320 BOT Spindle Center Line X
321 Spindle Center Line Y
322 Foot Pedal Tailstock Alarm
323 Disable Notch Filter
325 Manual Mode Enabled
326 Graphics X Zero Location
327 Graphics Z Zero Location
328 eHandwheel Rapid Limit
329 Main Spindle Jog Speed
330 MultiBoot Selection Time out
331 Sub Spindle Jog Speed
332 Foot Pedal Lockout
333 Probe Offset Z+
334 Probe Offset Z-
335 Linear Rapid Mode
336 Bar Feeder Enable
337 Safe Tool Change Location X
338 Safe Tool Change Location Y
339 Safe Tool Change Location Z
340 Chuck Clamp Delay Time
341 Tailstock Rapid Position
342 Tailstock Advance Distance
343 Sub Spindle SSV Variation
344 Sub Spindle SSV Cycle
345 Sub Spindle Chuck Clamping
346 Sub Spindle Chuck Unclamp RPM
347 Live Tooling SSV Variation
348 Live Tooling SSV Cycle
349 Live Tooling Chuck Clamping
350 Live Tooling Chuck Unclamp RPM
352 Live Tooling Speed Limit
355 Sub Spindle Speed Limit
356 Beeper Volume
357 WarmUp Compensation Cycle Start Idle Time
358 Steady Rest Clamp/Unclamp Delay Time
359 SS Chuck Clamp Delay Time
360 Steady Rest Foot Pedal Lockout
361 Bar Pusher Vent Time
368 Live Tooling Type
372 Parts Loader Type
375 APL Gripper Type
376 Light Curtain Enable
377 Negative Work Offsets
378 Safe Zone Calibrated Geometry Reference Point X
379 Safe Zone Calibrated Geometry Reference Point Y
380 Safe Zone Calibrated Geometry Reference Point X
381 Enable Touchscreen
383 Table Row Size
396 Enable / Disable Virtual Keyboard
397 Press and Hold Delay
398 Header Height
399 Tab Height
403 Change Popup Button Size
409 Default Coolant Pressure
410 Safe Tool Change Location B
413 Main Spindle Load Type
414 Sub Spindle Load Type
416 Media Destination
417 Chuck Unclamp Delay Time
418 SS Chuck Unclamp Delay Time
421 General Orient Angle
422 Lock Graphics Plane
423 Help Text Icon Size
424 Mist Extractor Condenser Time Out
