      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
G-code, M-code, and Setting
Service Home 269 - Second Home Position Y
This setting defines the Y-Axis position for second home, in inches or millimeters. The value is limited by the travel limits for the specific axis.
Press the [ORIGIN] button to set this setting to inactive or set the complete group to inactive.
NOTE
This setting is in the User Positions tab under Settings . Refer to User Positions for more information.
CAUTION
Incorrectly set user positions can cause machine crashes. Set user positions with caution, especially after you have changed your application in some way (new program, different tools, etc.). Verify and change each axis position separately.
