TL - 1/2 - TT - 4/8 - Motor - Replacment - AD0195 Rev B
Service Home How To Procedures TL-1/2 - TT-4 and ATT-4/8 Turret - Motor - Replacement
Recently Updated Last updated: 11/10/2025
AD0195
Applies to machines built from: September, 2004
- Jump to Section - 1. Introduction 2. Motor Replacement (8 steps) Back to Top
This procedure tells you how to replace the motor on a TT - 4 [1] and ATT - 4/8 [2] turret.
Machine Compatibility:
  • 93-2287 for TT-4 turrets made between 09/2004 - 10/2014
  • 93-2302, 93-3807 and 93-3808 for TT-4 turrets made between 09/2004 - 12/2014
  • 93-2302 for TT-4 turrets made between 12/2014 - 06/2016
  • 93-2580 for ATT-4 and ATT-8 turrets CHC machines with Sigma 5 motors.
  • 93-3305 for ATT-4 and ATT-8 turrets with 25T Gear on NGC machines.
  • 93-3317 for ATT-4 and ATT-8 turrets with 20T Gear on NGC machines.
 IMPORTANT: When upgrading motor from Sigma 1 to 5:
  •  93-3807 SIGMA 1 TO 5 CONTROL KIT only one is needed for each machine
  • 93-3808 SIGMA 1-5 CONVERSION BOXS AXIS KIT + 93-2302 SIGMA-5 TURRET ASSEMBLY is needed for each axis motor that is being upgraded. Refer to  Sigma 1 to 5 Conversion - Installation - AD0681 procedure for more information.
Motor Replacement
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker.
Use an approved lock with an approved safety tag.
Remove the servo-motor cover for the turret.
Disconnect the electrical cables from the servo-motor. Remove the gasket seal from the turret [2].
Clean the mating surfaces of the servo-motor [1] and the turret [2][3].
Install the new gasket seal on the turret [2]. Install the new servo-motor.
Torque the screws. Refer to Haas Fastener Torque Specifications. Use the value for steel.
Connect the electrical cables to the servo-motor.
Install the servo-motor cover.
IMPORTANT: If upgrading the motor from Sigma 1 to 5, the sigma convertor board must be installed. For more information, refer to Sigma 1 to 5 Conversion - Installation - AD0681 procedure.
Set the A-Axis Grid Offset. Do these steps:
Set Setting 7, Parameter Lock, to OFF.
Set Parameters 128 and 212 to values of 0.
Push [RESET] to stop each alarm.
Go into DEBUG mode.
Push [ZERO RETURN]. Push [A]. Push [SINGLE].
Note: Ignore the ZERO RETURN MARGIN TOO SMALL alarm.
Go into VAR and into RAW DATA.
Type GRID A on the RAW DATA Screen.
Set the Tool Change Offset, as follows:
Set Parameter 43 bit 18 (Invis Axis) to zero.
Go into [MDI] mode. Set the turret to tool 1 (T1). Use M43 to unclamp (disengage) the turret.
Push [EMERGENCY STOP] or M44 when the tool turret [1] is in the unclamped (disengaged) position [2].
Manually move the turret to tool 1.
Release [EMERGENCY STOP].
Push [RESET]
Push [EMERGENCY STOP].
Go to the POS-RAW-DATA screen.
Record the ACTUAL A-Axis position [1].
 Note: In this example the ACTUAL A-Axis position is 0.6612.
Go to Parameter 212.
Type the opposite value of the ACTUAL A-Axis position [1] without the decimal point.
 Note: For example the ACTUAL A-Axis position 0.6612 becomes -6612.
Get out of DEBUG mode.
Make sure the tool changer operates correctly. Operate this code in MDI mode:
For TT-4 and ATT-4:
T1; T2; T3; T4; T3; T2; M99;
For ATT-8:
T1; T2; T3; T4; T5; T6; T7; T8; T7; T6; T5; T4; T3; T2; M99;
