ST-10/15/20 - Sub-Spindle Pulleys and Motor - Replacement - AD0979
Service Home How To Procedures ST-10/15/20 - Sub-Spindle Pulleys and Motor - Replacement - AD0979
- Jump to Section - 1. Introduction 2. Remove Pulleys and Motor (5 steps) 3. Install Kit (6 steps) 4. Verification Back to Top
Recently Updated Last updated: 06/22/2026
AD0979
Revision A - 06/2026
This procedure describes how to remove and install the sub-spindle pulleys and motor for the ST-10/15/20 lathes fitted with the A2-5 Finishing Sub-Spindle
The procedure applies to the following kits:
  • 93-5617 Pulleys and Motor Replacement
Note: Service kit comes with 3 items. The pulley on the servo is sweat fit onto the shaft.
Important: Be sure to keep all hardware organized during the removal steps as they will be reused during reinstall.
Zero return B-Axis to home
Power off and lock out the machine
Remove sheetmetal [1] and [2] to expose sub-spindle
Remove back panel [1]
Note: A cooling fan is attached to the rear panel. Before fully removing the panel, disconnect the fan’s electrical connector to avoid damage
Remove head cover [2]
Remove service panel [3]
Break bolts [1] of the motor mount so that bolts are snug fit
Turn Cam Linear Guide [2] counterclockwise to loosen the tension on the belt
Remove bolts [3] to remove Sub-Spindle motor [4]
Note: Use service panel to gain access to bolts that mount the union to they spindle pulley
Remove bolts [1] to remove the union and draw bar [2]
Important: The union is heavy and if dropped it could lead to permanent damage. Have a surface near by with padding to lay the union and drawbar
Remove the belt [4]
To remove the spindle pulley [3] you must remove bolts [1] that bolt onto the spindle cartridge
Make sure to put aside the union spacer [2]
Install Kit
Install new spindle pulley [3] with union adapter [2] using bolts [1] onto the spindle cartridge
Lay belt [1] onto spindle pulley [3] teeth
Once the spindle pulley is mounted indicate the radial runout on face [1] to NTE 0.001" TIR
Then indicate the axial runout on face [2] to NTE 0.0005" TIR
Once adjusted torque bolts to 13 ft-lbs
Re-install union and drawbar [2] using bolts [1]
Note: Use service panel to gain access to bolt holes onto the union [2]
Once installed indicate the radial runout on face [3] to NTE .0005"
After alignment torque bolts [1] to 13 ft-lbs
Install new motor [2] using bolts [1] onto the motor mount
Ensure bolts [1] are torqued to 25 ft-lbs
Important: Make sure to engage pulley teeth with belt before tightening bolts
To tension the belt you turn the cam linear guide [3] in the clockwise direction
Tighten belt to 80 lbs and measure tension using a Gates Sonic Meter with parameters set to:
  • Mass: 3.5 g/m
  • Width: 15mm
  • Span: 160mm
Note: Check belt tension at different locations along the length of the belt. Manually turn the spindle to rotate the pulley
Once belt has been tightened tighten bolts [5] to 45 ft-lbs to secure motor mount
Re-check belt tension after torquing bolts. If out of specification, loosen bolts and repeat the procedure until within spec.
Re-install service panel [3]
Re-install head cover [2]
Re-install back panel [1]
Note: All bolts are to be toqrued to 13 ft-lbs
Re-Install sheet metal [1] and [2]
Verification
After all cables have been reconnected power up machine
In MDI input M143 P6000 which will rotate spindle the spindle forward at max RPM
Press [RESET]  to stop the spindle
Then in MDI input M144 P6000 which will rotate spindle the spindle in reverse at max RPM
