Lathe C-Axis Engagement Procedure Update
Service Home Service Updates Lathe C-Axis Engagement Procedure Update
May 05, 2020 Lathe C-Axis Engagement Procedure Update
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
The NGC Lathe C-axis no longer uses tool change offsets for orienting the C-axis relative to the Spindle. When the C-axis is commanded to engage, it commands the C-axis to its Zero position and commands the Spindle to the Spindle Orientation Offset position.
C-Axis - Engagement Offset - Lathe - NGC
The procedure has been updated by adding steps to:
  • Check the runout of the gear when the C-axis is engaged
  • Set the Spindle Orientation Offset a second time.
These steps will improve the C-axis engagement of the machine.
