NGC I/O PCB Firmware Update - Compatibility Table
Service Home Service Updates NGC I/O PCB Firmware Update - Compatibility Table
May 13, 2020 NGC I/O PCB Firmware Update - Compatibility Table
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
We wanted to let you know that we have added an I/O Firmware Compatibility Table on the I/O PCB Firmware Update - NGC procedure.
You will not be able to recover in the field if incompatible firmware is installed.  Before you update the firmware look at the part number that is located on the I/O PCB and make sure that you load the correct firmware version.
7/16"-14 UNC HSS-E Spiral Flute Tap, 0.323" Shank x 0.591" Thread Length, 2.5XD, Mod. Bottoming, 3 Flute, GH5, TiN Coated $30.95 $20.97
