NGC - I/O PCB - User Relays and Terminal Block Connectors - Installation - AD0411
Service Home How To Procedures Alarm Search: 174 NGC - I/O PCB - User Relays and Terminal Block Connectors - Installation - AD0411
Recently Updated Last updated: 07/10/2023
AD0411
- Jump to Section - 1. Introduction 2. Installation (3 steps) 3. Load Patch (1 step) Back to Top
This procedure will show you how to install the user relays and terminal block connectors on NGC I/O PCB P/N 34-3490B.
Machine Requirements:
  • I/O PCB board P/N 34-3490B or higher
  • Machines manufactured after 09/2018
Document applies to the follow service kits:
  • 93-2889 SVC KIT 120V IO BOARD RELAYS
Press Power OFF.
WARNING: Wait for the 320V indicator light on the vector drive to dim completely before you do work on electrical components
Remove the I/O PCB cover.
Locate the user relays sockets K7 - K11 on the I/O PCB.
Locate the TB terminal blocks on the I/O PCB. [1]
Install the relays into the socket.
Make sure the relay is correctly oriented relative to the socket.
Insert the contacts into the socket and push down firmly until the retention arm clicks in [2].
Install the terminal block connectors into the terminal blocks. The terminal block connectors are keyed and they only go one way.
Load Patch
IMPORTANT: If the user relays are used to activate M23/M24 for a machine without a Haas Robot Package, download the Legacy M Code Mapping configuration patch file.
Login to the HBC.HAASCNC.COM
Download the Legacy M Code Mapping configuration patch file.
  Note: The option files will appear on the configuration download page after the User Relay service kit has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
