    2. Українська
    2. Українська
Turret Lock and Unlocked Sensors – Adjustment - ST-10/10Y - ST -15/15Y - NGC - AD0685
Service Home How To Procedures Turret Lock and Unlocked Sensors – Adjustment - ST-10/10Y - ST -15/15Y - NGC - AD0685
Recently Updated Last updated: 07/19/2023
Revision 1
AD0685
- Jump to Section - 1. Introduction 2. Set up (1 step) 3. Lathe - Turret Lock Sensors - Adjustment (2 steps) 4. Lathe - Turret Unlock Sensors - Adjustment (2 steps) Back to Top
This procedure tells you how to adjust the turret locked and unlocked sensors on a machine with a Next Generation Control.
  • Turret locked sensor [1]
  • Clamp for the turret locked sensor [2]
  • Turret unlock sensor [3]
  • Clamp for the turret unlocked sensor [4]
  • 93-1223 TT CLMP/UNCLMP SRVC KIT
Machine Compatibility:
  • ST-10/10Y
  • ST-15/15Y
Set up
  • Enter service mode
  • Press [EMERGENCY STOP]
  • Press  [DIAGNOSTICS] -> [I/O]
  • Page down until the TOOL_TURRET_LOCKED and TOOL_TURRET_UNLOCKED bits are shown. (INPUTS 4 and 7)
  NOTE: You can filter the I/O values by pressing [ENTER] on each value so that a check mark appears to the far right. Then press [ALTER].
Do these steps. Monitor the DIAGNOSTIC screen at the same time:
  1. Loosen the lock sensor clamp. Move the lock sensor and clamp up until Tool Turret Locked changes to 0.
  2. Slowly move the lock sensor and clamp up. Find the location where the value is as near as possible to 1, but the value is 0.
  3. Put a mark on the turret lock cylinder on the outside of the lock sensor clamp.
  4. Repeat Step 1. Repeat Step 2, but move the clamp down. Repeat Step 3.
  5. Move the lock sensor and clamp to the middle point between the two marks. Tighten the clamp.
Push [A], [ZERO RETURN], then [SINGLE]. Make sure the Tool Turret Locked value is equal to 1. Operate this program in MDI mode.
T1;
G04 P1.;
T2;
G04 P1.;
M99;
This program makes sure the turret lock sensor operates correctly. Push [DIAGNOSTIC]. Make sure that Tool Turret Locked is 1 when the program operates the tool turret lock.
  1. Operate this code in MDI mode: M43.
  2. Loosen the unlock sensor clamp.
  3. Move the unlock sensor and clamp up until Tool Turret Unlocked. changes to 0.
  4. Slowly move the unlock sensor and clamp up. Find the location where the value is as near as possible to 1, but the value is 0.
  5. Put a mark on the turret lock cylinder on the outside of the unlock sensor clamp.
  6. Repeat Step 3. Repeat Step 4, but move the clamp down. Repeat Step 5.
  7. Move the unlock sensor and clamp to the middle point between the two marks. Tighten the clamp.
Push [A], [ZERO RETURN], then [SINGLE]. Make sure Tool Turret Locked is 1. Operate this program in MDI mode. This program makes sure the turret unlock sensor operates correctly:
T1;
G04 P1.;
T2;
G04 P1.;
M99;
Push [DIAGNOSTIC]. Make sure that Tool Turret Unlocked. changes to 1 when the program operates the tool turret unlock.
