Tap Breakage - Troubleshooting Guide - TG0144
Service Home Tap Breakage - Troubleshooting Guide - TG0144
Recently Updated Last updated: 10/15/2025
TG0144
Jump to Section 1. Introduction 2. Program Troubleshooting 3. Tap Troubleshooting 4. Material Troubleshooting 5. Hole Troubleshooting 6. Machine Troubleshooting 7. Coolant Troubleshooting Back to Top
This document explains some of the most common causes for tap breakage.
  • The RPM may be too high:
    • Set the RPM to a maximum of 3000, or 150 inches per minute feed, whichever comes first.
    • The DT-1 can tap at up to 5000 RPM.
  • If you are using a tension-compression holder:
    • Use 90% of the actual feed calculated for the thread to allow constant pressure on the tap as it enters and exits the hole.
    • Use 90% of the actual feed calculated for the thread if the machine does not have the Rigid Tap option.
  • Check the feedrate:
    • The speed and feedrate must be precise to maintain the correct synchronization between the tool and the Z-axis.
  • Keep the R-plane no shorter than 0.200” ( 5 mm) to give the machine some space to synchronize and accelerate.
  • If tapping small holes:
    • Put the machine to high gear (M42).
    • Tapping small holes in high gear speeds up the tapping process.
    • The high gear has less mass in the drive train to start and stop.
Tap Troubleshooting
  • Spiral flute taps:
    • Spiral flute taps are designed to pull chips out of the hole and away from the cutting area.
    • They work well when tapping a blind hole.
  • Spiral point taps:
    • Spiral point taps are designed to push chips forward and into the hole away from the cutting area.
    • They work well when tapping a through hole.
    • They do not work well in blind holes because the tapping chips can pack into the bottom of the hole and cause the tap to bottom.
  • Tap run out:
    • Make sure the run out is correct for the tap.
    • Some taps break if the TIR is more than 0.001" (.03 mm).
  • Make sure the tap is designed for use on CNC equipment:
    • Spiral flute taps work well and will eject chips from the working area.
    • Roll taps are stronger than cut taps and are recommended for small diameter tapping.
    • Hand taps are not designed for use on CNC machines.
  • Check the tap holding:
    • If the tap holder is a collet, make sure the tap does not slip.
    • If the tap holder is a collet, make sure the tap is not running out.
    • Taps must be held with a positive-drive device.
    • Make sure the collet is specifically designed to hold taps.
  • Hard Materials:
    • If the material is very hard, do not use coolant.
    • Clear the chips out of the holes and use a cutting fluid.
  • Soft Materials:
    • Soft, gummy materials require a consistent cooling mix.
    • They may also require special tapping compounds.
    • Check the coolant concentrations with a refractometer.
    • Always follow the manufacturer's mixing directions or use tapping solutions.
  • Check the hole depth:
    • Blind holes need be drilled at least 0.050” deeper than the tap is programmed to go.
    • The hole will be shallower than what is programmed because of the tip angle on the drill.
    • Setting an offset for the tip of the tool will make the hole shallow by the amount lost by the tip angle.
    • The program can compensate for this by drilling slightly deeper. This gives you the diameter required to the depth required.
  • Spot drill, then tap:
    • Spot drill a pilot hole before tapping.
    • This will insure that the drill is located accurately.
    • Drill the pilot hole slightly greater than the major diameter of the tap size.
  • Make sure the tap drill is the correct size:
    • For 75% of effective thread use this formula:
      • D - 1/N
      • D = major diameter of the tap
      • N = number of threads per inch
  • Hole dimensions:
    • A tapped hole with 75% of thread depth has only 5% less strength than 100% thread and takes only 1/3 of the cutting force of a 100% thread.
    • One and one half times the major diameter is the usual depth requirement for a tapped hole.
    • The strength of a threaded connection does not increase if the contact length is more than 1.5 times the diameter of the fastener.
    • Chances of breaking the tap increase dramatically when tapping more than one-and-a-half times the major diameter
  • Z Axis Overshoot and Drift:
    • Use an indicator and a simple, repeating incremental tapping program to test drift.
    • If the Z-Axis overshoots/drifts farther than what is programmed in the G84:
    • Parameter 120, SPINDLE ACC/DECEL adjusts the amount the Z axis can overshoot.
    • Parameter 144, RIG TAP FINISH DIST also adjusts the amount the Z axis can overshoot.
  • Rigid Tapping:
    • If the customer has rigid tapping, make sure Parameter 57:4 RIGID TAP is ON.
  • Peck Tapping:
    • If the customer is tapping the same hole more than once (peck tap), make sure Setting 133 REPEAT RIGID TAP is ON.
    • Prior to mill version 12.09 REPEAT RIGID TAP was turned on with Parameter 57:6.
  • Tap Retract:
    • Setting 130, TAP RETRACT SPEED, controls the speed at which the tap retracts.
    • Reduce the value in this setting if cross-threading or tearing occurs.
  • Spindle Encoder:
    • Inspect the spindle encoder. For more information, please refer to the Spindle Non-Contact Encoder (NCE) - Troubleshooting Guide.
  • Tapping Compound:
    • If coolant may be the cause of the problem, program a series of holes and brush a tapping compound or tapping oil on the tap instead of coolant.
    • Tap Magic makes several different types of high quality tapping fluid.
  • Coolant Condition:
    • Always follow the coolant manufacturer's recommendations for mixing coolant.
    • Make sure the water has a low mineral content. Minerals in the water break down the quality of the coolant and reduce the coolant's effectiveness.
