Replacing Counterbalance components
Service Home Service Updates Replacing Counterbalance components
January 04, 2019 Replacing Counter Balance components
When servicing or repairing machines with Hydraulic Counter Balance systems, it is no longer required to replace the entire system when a single component such as a pressure gauge or pressure switch fails.
If a component such as the Cylinder, Tank, or hose has failed, the entire system should still be replaced.
If you encounter such a failure, we encourage the service techs to use their discretion to determine the condition of the Hydraulic system and repair the system in the best possible way.  We encourage the servicing tech to take into consideration Customer down time, the costs of the replacement parts and avoid invasive service procedures, if the condition of the machine allows.
If a Pressure Gauge or Pressure Switch has failed, simply replace these components and recharge the system.  These replacement parts are available on Haasparts.com.
We encourage the techs to explain the various repair options available to the customer and provide them with the repair best suited for their needs.
