      • Rotary Workholding Kits
BOT TOOLHOLDING
HAAS TESTED. HAAS PROVEN.
SEE ALL BOT TOOLHOLDING
  2. Lathe Toolholding
  3. BOT Static Turning Holders
BOT TURRETS
Haas BOT Toolholders
Set up your Haas BOT turret with the best tools available. Haas bolt-on style tool turrets provide super-rigid mounting of turning tools and boring bars. The turrets accept industry-standard bolt-on toolholders around the perimeter, and have radial slots on the face for mounting turning tools in either the right- or left-hand direction.
  • Industry-standard bolt pattern
  • Black oxide coating for corrosion resistance
  • Haas-designed OEM tooling
LATHE TURRET COMPATABILITY
What Holders Fit My Lathe?
_____________________________________
Figuring out what toolholders fit your lathe can be challenging at times and can lead to a lot of confusion.  Haas offers toolholders for 4 lathe turret types. All of these are dependent on what model your machine is and what options were added.
BOLT-ON
  12-STATION
TOOLHOLDER SERIES & COMPATIBLE LATHES
BOT10
ST-10,  ST-10L,  ST-15, & ST-15L
SHOP BOT10
BOT20
ST-20, ST-20L, ST-25, ST-25L, ST-28, ST-28L, ST-30, ST-30L, ST-35, & ST-35L
SHOP BOT20
BOT40
ST-40*, ST-40L*, ST-45*, ST-45L*, ST-50, & ST-55
SHOP BOT40
BOT50
SHOP BOT50
*Fits standard turret and optional 7.25" (184 mm) thick turret.
VDI
12-STATION
VDI40
ST-10, ST-10L, ST-10Y, ST-10LY, ST-15, ST-15L, ST-15Y, ST-15LY, ST-20, ST-20L, ST-25, ST-25Y, ST-28, ST-28L, ST-30, ST-30L, ST-35, ST-40, ST-40L, ST-45, & ST-45L
SHOP VDI40
VB HYBRID
12-STATION
BOT10
VDI40
ST-10, ST-10L, ST-10Y, ST-10LY, ST-15, ST-15L, ST-15Y, & ST-15LY
SHOP BOT10
SHOP VDI40
BOT20
VDI40
ST-20, ST-20Y, ST-25, ST-25Y, ST-30, ST-30Y, ST-35, & ST-35Y
SHOP BOT20
SHOP VDI40
BOT40
VDI40
SHOP BOT40
SHOP VDI40
VB HYBRID
24-STATION
BOT24
VDI40
DS-30SS, DS-30SSY, ST-20SS, ST-20SSY, ST-30SS, & ST-30SSY
SHOP BOT24
SHOP VDI40
Toolholder Types
Internal (ID) Turning Holder
  • OEM tooling designed to fit your Haas lathe turret
  • Inch and metric sizes available
  • Through-tool coolant back cover plate included
  • Interchangeable front coolant nozzles
Face Groove Holder
  • Includes wedge clamp for rigid holding of the tool shank
  • Available for inch and metric shank sizes
  • Holds tool shank parallel to spindle centerline
Clamp
  • Wedge and/or block style available
  • Wedge and block clamps hold inch and metric shanks
  • Secure rigid holding of the turning tool
  • Bolted or pinned for proper alignment
Coolant Block
  • Easiest way to deliver coolant to the cutting area
  • Top and bottom coolant nozzles for best coolant delivery
  • Black-oxide coating for corrosion resistance
  • Includes all necessary hardware for immediate use
Toolholder Kits
  • Kits can include internal turning holder, coolant blocks, external turning holder, and more
  • Inch and metric kits available
External (OD) Turning Holder
  • Interchangeable coolant nozzles
BOT10 Toolholding
BOT10 Toolholding
17 9 9 9 9 9 items
BOT20 Toolholding
BOT20 Toolholding
22 12 12 12 12 12 items
BOT24 Toolholding
BOT24 Toolholding
16 8 8 8 8 8 items
BOT40 Toolholding
BOT40 Toolholding
8 3 3 3 3 3 items
BOT50 Toolholding
BOT50 Toolholding
4 1 1 1 1 1 items
