      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Hardness Tester
Portable EDM
REDUCTION SLEEVES
HAAS TESTED. HAAS PROVEN.
SEE ALL REDUCTION SLEEVES
  2. Lathe Toolholding
  3. Turning Holder Reduction Sleeves / Bushings
REDUCTION SLEEVES OVERVIEW
Reduction Sleeves for ID Toolholders
Expand the useful range of your large-diameter ID toolholders with these high-quality reduction sleeves. Simply slide the appropriate sleeve into the larger bore of the toolholder to adapt it to handle smaller tools.
  • Expand the range of your existing ID toolholders
  • Black oxide coating for corrosion resistance
  • Haas-designed OEM tooling
REDUCTION SLEEVE TYPES
HAAS TOOLING REDUCTION SLEEVE TYPES
C-TYPE - SLOTTED
  • Slotted side hole allows for a versatile fit across many toolholders series
  • Great for holding shank tools, drills, boring bars, reamers, and more
  • Expand the capabilities of your ID toolholder
SHOP C-TYPE SLEEVES
LB-TYPE - TWO HOLED
  • Specific hole spacing for a tighter fit  in the toolholder
  • Inch hole spacing - 2.75"
  • Metric hole spacing - 69.85mm
  • Added set screw for easier tool setup
SHOP LB-TYPE SLEEVES
Note: This sleeve type is currently only available in the U.S.
