MODULAR BORING BARS OVERVIEW
Modular Boring Bars / Internal (ID) Turning Tools
Modular Boring Bars are a popular alternative to conventional solid one-piece indexable boring bars. Consisting of a two-piece assembly – a bolt-on head and a boring bar body – modular boring bars offer greater flexibility in setup and can deliver better performance compared to traditional boring bars. With the ability to swap out any compatible bolt-on serrated head, tasks such as profiling and linear boring can all be performed without the need to switch to an entirely different tool.
Modular Boring Bars, available in various styles and sizes, are designed with a through-tool coolant and a serrated bolt-on locking interface to ensure the most optimal tool securement and performance. Offering overhangs ranging from 5xD to 10xD, with the option for anti-vibration damping features. Anti-vibration damped boring bars are equipped with an internal pre-tuned damping system engineered to deliver superior performance and reduce chatter during operations.
Modular Bolt-on Boring Heads, available in a wide range of styles and sizes, are designed with a serrated bolt-on locking interface to ensure a secure and reliable connection. These heads are cost-effective and offer excellent flexibility for high-volume production. Simply swap the bolt-on boring head, there’s no need to replace the entire boring bar. Integrated through-tool coolant ensures optimal lubrication and chip evacuation, enhancing tool life and overall performance.
ANTI-VIBRATION BORING BARS OVERVIEW
Anti-Vibration Damped Boring Bars / Internal (ID) Turning Tools
Anti-Vibration Damped Boring Bars are a revolutionary series in the industry, featuring advanced internal pre-tuned damping technology. These boring bars are the ideal solutions for deep-hole boring applications. Constructed of either steel or carbide, they are designed to reduce vibration, minimize chatter, improve surface finish, and enable precision boring at extreme overhangs (7xD to 10xD).
With interchangeable modular bolt-on heads, Anti-Vibration Damped Boring Bars offer exceptional flexibility to streamline productivity. Their modularity allows for quick and easy changes between compatible head styles, without compromising performance – while also reducing the need for excess inventory.
  • Anti-Vibration Damped boring bars allow overhangs from 7x shank diameter to 10x shank diameter, compared to 5x shank diameter for carbide and 3x shank diameter for steel.
  • Recommended to adjust the boring bar to the shortest possible length, based on desired cut depth; this will provide maximum rigidity.
  • Select the largest possible shank diameter (with space for chip evacuation); this will provide the best performance from the tool.
  • For optimal clamping force, the use of split bushing is recommended. 3xD to 4xD clamping length is recommended.
Choosing Modular Boring Bars
Features
Modular Boring Bar
Conventional Boring Bar
Cost
Lower (Long-Term)
Higher
Set-up Time
Lower (Long-Term)
Higher
Performance
Higher
Lower
Inventory
Lower
Higher
*Modular Boring Bars allow for quick set-up time after initial indicating, with the ability to change bolt-on heads for maximum flexibility while minimizing inventory. With options like Anti-Vibration dampened systems, modular boring bars allow for the best performance per part. *
How to choose Modular Boring Bar Body
  1. Determine your Shank Diameter [øDMM]
    To have the best performance out of your boring bar; Determine your shank diameter to have the best Diameter-to-Stick out ratio. Selecting the largest shank diameter possible based on workpiece is recommended; chip evacuation space is needed to avoid chip packing.
  2. Determine what type of boring bar you need.
    Carbide and Anti-Vibration boring bars are commonly used when longer stick out is required.
  3. Determine Hub Diameter [øC].
    Determining Hub Diameter can be done before or after selecting your preferred Bolt-on Head. Refer to parametric drawing to determine what diameter hub is needed for your application.
  4. Determine Overall Length [OAL] required.
    Overall Length is very important feature that is overlooked. The ideal Overall Length for a boring bar is determined by the job requirement, while also including 3xD to 4xD for bar clamping for optimal rigidity.
How to choose Modular Bolt-On Head
  1. Determine your Minimum Machining Diameter [øD].
    To have the best performance out of your boring bar; Determine your minimum machining diameter to have the best Diameter-to-Stick out ratio. Utilizing the largest shank diameter possible based on workpiece is recommended; chip evacuation space is needed to avoid chip packing.
  2. Determine Insert Style.
    Insert styles range from 80˚ Rhombic, 55 ˚ Rhombic, 35 ˚ Rhombic, and T style Inserts; Inserts can also be determined by Inscribed Circle Diameter [IC] and Cutting-Edge Length [L10]. Different types of jobs require different types of inserts, from roughing, finishing, and profiling. Select which is best for your application.
  3. Determine desired clamping Style.
    Clamping styles are commonly associated with different types of tool holding. See chart for best comparison.
  4. Determine Hub Diameter [øC].
Linear cutting     →     Copying/Profile
Linear Machining
Copying / Profile Machining
  • Stronger Cutting Edge
  • Better Access to features
  • Higher Cutting forces
  • Lower Cutting forces
  • Higher Material Removal Rate
  • Weaker cutting edge
  • More Vibration
  • Less Vibration
INSERT STYLES
  • Insert Styles
  • Chipbreakers
  • Insert Grades
Insert Styles
C-Style Inserts – 80° Rhombic
For external machining and facing. The large point angle is very rigid, and good for rough machining. This is the most commonly used insert.
D-Style Inserts – 55° Rhombic
The smaller point angle of this insert is more versatile for finishing and detail work, but it has less cutting-edge strength than other geometries.
V-Style Inserts – 35° Rhombic
T-Style Inserts – 60° Triangle
For internal machining. The 60° cutting angle provides medium cutting-edge strength that allows for both ID roughing and finishing applications.
W-Style Inserts – 80° Trigon
This insert has 3 cutting edges per side. The 80° cutting angle provides high cutting-edge strength for roughing, but the depth of cut is limited by the short cutting edge.
LARGE NOSE ANGLE
• Stronger cutting edge
• Higher cutting forces
• More vibration
• Higher feedrates
SMALL NOSE ANGLE
• Better access to features
• Lower cutting forces
• Lower vibrations
Chipbreakers
HFF
HAL
For cost-effective machining of aluminum, non-ferrous metals, and plastics. Extremely sharp cutting edges result in optimum part finishes with low cutting forces and short chips.
HFP
HFF
For finish turning operations, producing smooth, accurate surfaces. Very good chip control, especially at low depths of cut.
HFS
HFP
For finish to medium turning operations, with optimal chip control over a wide range of cutting conditions and workpiece materials.
HKR
HFS
For finish turning operations. Ground periphery with positive cutting edge ideally suited for high-temp alloys. Micro-finished edge on the ground periphery adds just a slight hone for improved edge integrity and reliability.
HML
HMA
For finish to rough turning operations. Flat-top geometry for machining cast iron.
HMP
HML
For finish to medium turning operations, with a negative, stable cutting edge.
HMR
HMP
For medium to rough turning operations, with reduced cutting forces and improved chip control for high feed rates. Suitable for high metal removal rates and spindling applications.
HMS
HMR
For light to medium rough-turning operations. Excellent choice for steels, difficult-to-machine high-alloy titanium, and aluminum materials. High strength to deal with heavy chip deformation.
HMU
HMS
For medium turning operations. Primarily used with high-temp materials. Utilizes a micro-finished edge preparation to increase edge toughness.
HRH
HMU
For medium turning operations. Medium universal geometry with a soft cutting action due to its positive profile. Versatile application range well suited for boring operations and turning unstable components.
HUF
HRH
For medium to rough turning operations. Outstanding chip control. High edge strength for interrupted cuts, forging skin, or scale. Preferred for all cast iron, such as gray, malleable, and nodular.
HUM
HUF
For finish turning operations, with a positive cutting edge for reduced cutting forces and superior surface quality.
HUR
HUM
For medium turning operations, with a soft-cutting chipbreaker. Used in applications producing varying chip sections, such as profile or copy turning. Good dimensional accuracy. For soft steel materials and stainless steels.
HUR
HUR
For rough turning operations. Improved chip forming and coolant flow for increased tool life. Positive geometry reduces cutting forces and improves depth-of-cut notching resistance. Suitable for stainless steel and smooth machining of steel.
HUR
HM
For medium turning operations. Excellent chip control in various conditions for increased productivity. Variable land reduces cutting loads at high speeds and feeds, promoting stable tool life.
HUR
AL
For finish to medium turning operations. High rake angle and a low resistance cutting edge for extended tool life in continuous cutting of aluminum, non-ferrous metals, and plastics.
HUR
HSF
For finish hard turning operations. Excellent chip control with a unique anti-vibration tip structure. Good dimensional accuracy. Excels at cutting high-hardness materials between 40-62 HRC.
Insert Grades
Choose the grade that best matches your application and workpiece material.
DECODING HAAS GRADES: HTP15
BRAND
H
Haas
APPLICATION
T
Turning
PRIMARY WORKPIECE MATERIAL
P
  P – Steel
  M – Stainless Steel
  K – Cast Iron
  N – Non-Ferrous
  S – High-Temp Alloys
  H – Hardened Materials
  U – Universal Machining
APPLICATION RANGE
10 – Uninterrupted
15 – Light Interrupted
20 – Medium Interrupted
25 – Medium Interrupted
35 – Heavy Interrupted
WEAR RESISTANCE
20
TOUGHNESS
25
30
35
SMOOTH
SURFACE
MEDIUM TO
ROUGH SURFACE
ROUGH
SURFACE
Smooth Cut
Pre-Turned
Lightly
Interrupted
Heavily
Interrupted
CLICK + TO EXPAND
CCET Insert Grades
CLAMPING STYLES
Clamping Styles
M – Multi-Lock System*
• For negative-style inserts
P – Lever-Lock System
S – Screw-On System
• For positive-style inserts
D – Double-Clamp System
• Powerful single-lever screw clamping
• Spring design releases clamp automatically
• Optimized for chip flow
• Eccentric lock pin secures the insert against the side
• Top clamp provides rigid downward clamping
S – Screw-On System
* For multi-lock holders: Rotate the eccentric lock pin counterclockwise until the insert drops on, and then rotate the eccentric pin clockwise to secure the insert against the side of the holder. Install the top clamp to hold down the insert.
  2. Lathe Tooling
  3. Indexable Antivibration Boring Bars
