      • Coating Thickness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
Hardness Tester
QUICK-CHANGE COLLET CHUCKS
HAAS TESTED. HAAS PROVEN.
SEE ALL LATHE COLLET CHUCKS
15% OFF Collet Chuck Bundle
CHOOSE A COLLET CHUCK + A COLLET CHANGING TOOL + AT LEAST 4 QUICK-CHANGE COLLETS = 15% OFF
You must add 1 collet chuck, 1 collet changing tool, and a minimum of 4 quick-change collets (No Max) to your cart to receive 15% off your Collet Chuck Bundle.
Discount will be shown in your cart, once all items are added.
  2. Lathe Workholding
  3. Quick-Change Collet Chucks
LATHE COLLET CHUCKS OVERVIEW
Lathe Collet Chucks
Lathe Quick-Change Collet Chucks are great options for shops looking to decrease lathe set-up times. The average job shop changes their machine setup two to three times a day. By replacing the standard 3-jaw chuck with a quick-change collet chuck, the changeover from one size material to another is done in just a few seconds – the time it takes to change a collet.
NOTE: Quick-change collets sold separately.
  • Easily change the collet in seconds (requires handheld collet changing tool)
  • Grips the part evenly and with more force
  • High repeatability and concentricity
  • Larger gripping range
  • Sealed design for long life and minimal maintenance
  • Minimizes coolant going through the spindle drawtube
Part Transfer Minimum Distance
NOTE: Ensure that your part transfer distance is suitable for your application. The part transfer minimum distance will vary depending on your machine and collet chucks.
For dual-spindle applications, we recommend referring to your machine's dedicated machine layout drawing (MLD) to determine the face-to-face distance between spindles.
For legacy machines, this distance may be manually measured.
After subtracting the overall length of your chucks from the spindle face-to-face distance, determine if the resulting part transfer minimum distance is too large for your intended workpiece. Alternative solutions may be required for proper part transfers.
