      • Rotary Workholding Kits
QUICK-CHANGE COLLETS
HAAS TESTED. HAAS PROVEN.
SEE ALL QUICK-CHANGE COLLETS
15% OFF Collet Chuck Bundle
CHOOSE A COLLET CHUCK + A COLLET CHANGING TOOL + AT LEAST 4 QUICK-CHANGE COLLETS = 15% OFF
You must add 1 collet chuck, 1 collet changing tool, and a minimum of 4 quick-change collets (No Max) to your cart to receive 15% off your Collet Chuck Bundle.
Discount will be shown in your cart, once all items are added.
  2. Lathe Workholding
  3. Quick-Change Collets
QUICK-CHANGE COLLETS OVERVIEW
Quick-Change Collets are the preferred choice for increased productivity. Using collets eliminates the need for having multiple jaw sets for all your turning needs. You also do not need to have qualified operators changing jaws on the machine for each setup. These collets are compatible with ALL competitors’ collet chucks of similar size and type.
  • Collets are compatible with ALL other brands of collet chucks that are similar in size and type
  • Easily change the collet in seconds
  • Rubber grip design prevents material or part damage
  • Large gripping range (0.04 in / 1.0 mm)
  • Designed to grip the part evenly throughout the range
  • Consistent concentricity
  • Rubber grip virtually eliminates coolant going through the spindle drawtube
  • Sealed design keeps chips from entering the chuck, for long life and minimal maintenance
