      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
Hardness Tester
Portable EDM
  2. Measuring & Inspection
  3. Depth Measuring
Depth Measuring Details
Haas Tooling offers a complete lineup of depth micrometers from digital, standard, and dial styles. Used as a calibration standard, depth micrometers provide precise and reliable depth measurements for quick inspections of slots, pockets, or raised surfaces.
  • Available in inch (U.S. Only) and metric configurations
  • Depth micrometers are made in accordance with DIN863
Depth Micrometer - Standard & Digital
________________________
Haas Depth Micrometers are available in standard and digital configurations. Depth micrometers are designed to measure the depth of slots, pockets, or raised surfaces.
  • Offered in standard and digital configurations
  • Available in inch (U.S. Only) & metric thimbles
  • Made in accordance with DIN863
  • Ratchet stop thimble
  • Extension rods capable of measuring up to 6.0 in \ 150.0mm
  • Spindle thread is hardened, ground, and lapped for ultimate accuracy
Filter For Depth Micrometers
Filter For Digital Depth Micrometers
Depth Gauge - Dial Only
Allows shops to measure the depth of holes and parts that feature a groove or elevated surface. An easy-to-read dial makes measuring quick and efficient.
  • Available in Inch (U.S. Only) & Metric
  • Hardened base with fine-lapped contact surface
  • Extension rods capable of measuring up to 6" and 100mm
Filter For Depth Gauges
