      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
Hardness Tester
Portable EDM
EDGE & CENTER FINDERS
HAAS TESTED. HAAS PROVEN.
SEE ALL EDGE & CENTER FINDERS
  2. Measuring & Inspection
  3. Edge & Center Finders
EDGE & CENTER FINDERS OVERVIEW
Accurately locating the position of your workpiece is a critical step in any machining process. If your mill doesn’t have a built-in probing system, Haas Tooling offers different options to cover your edge finding needs – choose from the traditional mechanical, electronic, or the modern Haimer 3D-Sensor style.
The Haimer 3D Sensor. Meet your new favorite tool! It doesn’t just do the job of an indicator and an edge finder – it does the job better.
Universal Haimer 3D sensors from Haas are the perfect complimentary tool for all CNC shops, big and small. They are engineered to provide precise measurements and allow for the edge to be found on the first attempt. The sensor eliminates problems with calculations, creating fewer errors and reducing setup time, optimizing your spindle time.
The Haimer sensor can be equipped with a long or short probe tip. They can be changed out with no re-calibration of the unit. Offered individually or in packs of 3 at a low price, these probe tips are compatible with all Haimer 3D sensors. Haas top-quality tools provide the accuracy you need, at prices that won’t break the bank.
Videos
