      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
Hardness Tester
Portable EDM
  2. Measuring & Inspection
  3. Threaded Plug & Ring Gauges
Threaded Plug & Ring gauges Overview
Plug & Ring Gauges
Haas offers a full range of Plug & Ring Gauges made from hardened steel, rated at 58-63 HRC. Plug and ring gauges are designed for GO/NO-GO testing of threaded features on machined parts. Ring gauges are meant to check external threaded features while plug gauges are ideal for checking internal threaded features. Both gauges ensure thread quality and pitch diameter are within tolerance. Haas plug & ring gauges are manufactured to ANSI B1.2/DIN ISO 1502 standards. An inspection report is included with each set and/or individual gauge, outlining the true measured dimensions.
Plug Gauges
Available in the following threads:
  • Metric: M3x0.5 - M18x2.5
  • Inch: #6-32 - ½”-20
SHOP SINGLES
SHOP SETS
Ring Gauges
SHOP SINGLES
SHOP SETS
THREADED PLUG & RING GAUGE VIDEOS
Threaded Ring Gauges
Threaded Plug Gauges
Threaded Plug and Ring Gauges
IMTS 2024
