HDC-3
HDC-3
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
3-Axis CNC double-Column Mill with 150" x 106" x 39" travels
The HDC-3 is a 3-axis double-column mill designed for large-part machining, such as airframe components, large molds, and heavy structures. The machine’s rigid construction provides a very stable cutting platform. The fully supported X-axis travels easily handle parts weighing up to 10,000 lb (4536 kg).
  • Rugged 50-taper inline direct-drive spindle
  • 50+1 side-mount tool changer
  • Control pendant on moveable stand for easy access
  • 150" x 64" (3810 x 1626 mm) T-slot table
  • Fully supported X-axis travel
  • 10,000 lb (4536 kg) part capacity
NOTE: Machine comes standard with a T-slot table.
See Available Stock
Current Lead Time
  • 50 Taper
  • 3 Axis
  • 7500 RPM
  • 50+1 Tool Capacity
Compare Machines
BUILD & PRICE
Available for order in North American, with estimated delivery Q1 2026.
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
Travels S.A.E METRIC
X Axis 150.00 in 3810 mm
Y Axis 106.00 in 2692 mm
Z Axis 39.00 in 991 mm
Spindle S.A.E METRIC
Max Rating 60.0 hp 44.7 kW
Max Speed 7500 rpm 7500 rpm
Max Torque 170.0 ft-lbf @ 1800 rpm 230.0 Nm @ 1800 rpm
Taper CT or BT 50 CT or BT 50
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Coolant Jacket Coolant Jacket
Table S.A.E METRIC
Length 150.0 in 3810 mm
Width 64.0 in 1626 mm
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Between Columns 73.5 in 1867 mm
Bridge Clearance 51 in 1,295 mm
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full)** 4.0 in 102 mm
Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
Max Tool Length (from gage line) 16.00 in 406 mm
Max Tool Weight 30.0 lb 13.6 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 7500 rpm 7500 rpm
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
AVAILABLE OPTIONS
RELATED PRODUCTS
Standard Features
  • High-Performance 7500-rpm Spindle
  • 50+1 Side-Mount Tool Changer, 50-Taper
  • Chip Auger
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Rigid Tapping
  • ECO Mode
  • Stainless Steel Way Covers
  • HDC Camera Monitor System
  • Phone Charging Stand
  • Machine Anchoring Kit
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Anchoring Template
  • Layout Drawing (Coming Soon)
  • Torque Chart
RELATED PRODUCTS
5-Axis Version
Haas HDC-3-5AX
HDC-3-5AX
5-Axis CNC double-Column Mill with 150" x 106" x 43" travels
  • HSK-A100 Taper
  • 5 Axis
  • 6000 RPM
    CNY ONLY
Learn More Build & Price
Different Approach
Haas VS-3
VS-3
Vertical Machining Center; 150" x 50" x 50" (3810 x 1270 x 1270 mm)
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
    CNY ONLY
Gantry Mill Alternative
Haas GM-2
GM-2
3-Axis CNC Gantry Mill with 145" x 87.5" x 22" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Build & Price
Get Started
Need More Information?
