HDC-3-5AX
  1. Vertical Mills
  2. Double-Column Mills
  3. models
  4. HDC-3-5AX
HDC-3-5AX
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC double-Column Mill with 150" x 106" x 43" travels
The HDC-3-5AX is a 5-axis double-column mill designed for complex, large-part machining, such as airframe components, layup molds, and composite structures. The machine’s rigid construction provides a very stable cutting platform. The fully supported X-axis travels easily handle parts weighing up to 10,000 lb (4536 kg).
NOTE: The table surface consists of three blank tooling plates that are easily machined for custom fixturing. Optional T-slot plates are available.
  • Dual-axis spindle head provides ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • HSK-A100 integral-motor spindle
  • 50+1 side-mount tool changer
  • Control pendant on moveable stand for easy access
  • 153" x 49" (3886 x 1245 mm) table, with 3 blank bolt-on tooling plates for custom fixturing
  • Fully supported X-axis travel
  • 10,000 lb (4536 kg) part capacity
See Available Stock
Current Lead Time
  • HSK-A100 Taper
  • 5 Axis
  • 6000 RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
Travels S.A.E METRIC
X Axis 150.00 in 3810 mm
Y Axis 106.00 in 2692 mm
Z Axis 43.00 in 1092 mm
Spindle S.A.E METRIC
Max Rating 60.0 hp 44.7 kW
Max Speed 6000 rpm 6000 rpm
Max Torque 110.0 ft-lbf @ 3000 rpm 149.0 Nm @ 3000 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper HSK-A100 HSK-A100
Bearing Lubrication Grease Packed Grease Packed
Cooling Liquid Cooled Liquid Cooled
B Axis - Tilt S.A.E METRIC
Travel ±120˚ ±120˚
Max Speed 68 °/sec 68 °/sec
Torque (Continuous) 944 ft-lbf 1279 Nm
Brake Torque 1239 ft-lbf 1680 Nm
Gear Ratio 59:1 59:1
Timing 4:1 4:1
C Axis - Rotation S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Speed 170 °/sec 170 °/sec
Torque (Continuous) 900 ft-lbf 1220 Nm
Brake Torque 2000 ft-lbf 2712 Nm
Gear Ratio 105.83:1 105.83:1
Timing 1:1 1:1
Table S.A.E METRIC
Length 153.0 in 3886 mm
Width 49.0 in 1245 mm
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Between Columns 73.5 in 1867 mm
Bridge Clearance 51 in 1,295 mm
Feedrates S.A.E METRIC
Rapids on X 360 ipm 9.1 m/min
Rapids on Y 400 ipm 10.2 m/min
Rapids on Z 600 ipm 15.2 m/min
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full)** 4.0 in 102 mm
Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
Max Tool Length (from gage line) 16.00 in 406 mm
Max Tool Weight 30.0 lb 13.6 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 6000 rpm 6000 rpm
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
Domestic Pallet for Sheet Metal Crate 96 in x 72 in x 60 in 244 cm x 183 cm x 152 cm
Weight for Sheet Metal Crate 2280 lb 1034 kg
Domestic Pallet, Column Assembly 150 in x 102 in x 87 in 381 cm x 259 cm x 221 cm
Domestic Pallet, Table Assembly 376 in x 91 in x 66 in 955 cm x 231 cm x 168 cm
Weight, Column Assembly, Domestic 7,260 lb 3,293 kg
Weight, Table Assembly, Export 20,860 lb 9,462 kg
Domestic Pallet, Bridge Assembly 240.0 in 120.0 in 133.0 in 610 cm 305 cm 338 cm
Weight, Bridge Assembly, Domestic 23,280 lb 10,560.0 kg
Domestic Pallet for Sheet Metal Crate #2 96.0 in 72.0 in 92.0 in 243.8 cm 182.9 cm 233.7 cm
Weight for Sheet Metal Crate #2, Domestic 2,340 lb 1,061.0 kg
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
AVAILABLE OPTIONS
RELATED PRODUCTS
Standard Features
  • 6000-rpm Spindle, HSK-A100
  • 50+1 Side-Mount Tool Changer, HSK
  • Wireless Intuitive Probing System, RF
  • Chip Auger
  • Chip Tray Filter Kit
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • CNC Control Cabinet Cooler
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Dynamic Work Offsets and Tool Center Point Control
  • Rigid Tapping
  • ECO Mode
  • Stainless Steel Way Covers
  • HDC Camera Monitor System
  • Phone Charging Stand
  • Machine Anchoring Kit
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Anchoring Template
  • Layout Drawing
  • Torque Chart
RELATED PRODUCTS
Gantry-Style Mill
Haas GM-2-5AX
GM-2-5AX
5-Axis CNC Gantry Mill with 145" x 87.5" x 39.3" travels
  • HSK 63F Taper
  • 5 Axis
  • 20k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Different Approach
Haas VR-11
VR-14
5-Axis Vertical Machining Center; 150" x 40" x 42", 2-axis head
  • HSK-A63 Taper
  • 5 Axis
  • 20k RPM
    CNY ONLY
Need More Information?
