      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
40MM - Ballscrew Cartridge Bearing - Upgrade - AD0584
Service Home How To Procedures 40MM - Ballscrew Cartridge Bearing - Upgrade - AD0584
Recently Updated Last updated: 03/25/2025
AD0584
- Jump to Section - 1. Introduction 2. Installation (3 steps) Back to Top
This procedure tells how to upgrade the black oxide bearing to the improved bearing upgrade kit P/N 93-2282.
Prerequisites
  • Machines with the new style ballscrew.
Use the link as an additional reference for Ballscrew - Installation Tools and Torque Specifications.
Remove the black oxide bearing pack assembly from the motor mount. Inspect and clean the bearing surfaces.
Install the cartridge bearing [A] to the motor mount with bumper mounting holes oriented perpendicular to the face. Tighten the bearing using the included hardware [B].
Install the bumper [C] to the face of the bearing.
Important: Inspect the ballscrew bearing journal and shoulder. This surface must be clean and burr-free.
Carefully install the ballscrew [1] into the motor housing assembly.
Install the spacer [2].
Install the locknut [3] on ballscrew with the relieved shoulder facing the bearing pack.
