Ballscrew - Installation Tools and Torque Specifications
Recently Updated Last updated: 03/24/2022
This document tells you the tools you need to install ballscrew components and the correct torque specifications for those components.
Ballscrew Installation Tools
Tool 32mm 40mm 50mm 50mm
(Larger Motor Housing)
A Coupler - Installation Tool - "Pacman"
Note: This spacer is included with the coupler.
B Collar Nut Socket- Bearing Pack End
T-1069 (Short)
T-0047 (Long)
T-1542A T-1542A T-2098
C Collar Nut Socket- Bearing Support End
T-1069 (Short)
T-0047 (Long)
T-1542A T-1542A T-1542A
D Collar Lock Tool - Bearing Pack End T-1601 T-1555 T-1555 T- Handle
E Collar Lock Tool - Bearing Support End T-1601 T-1555 T-1555 T-1555
F Hex Bit for the Collar Nut - Pinch Bolt Hex bit; 4mm X 1/4" drive X 4"
G Hex Bit for the Coupler Hex bit; 3/16" X 1/4" drive X 4" Hex bit; 6 mm X1/4" drive X 4"
H Torque Wrench Adapter for 1/4" Hex Bit Adapter; 3/8" socket drive to 1/4" female hex
I Torque Wrench
Ballscrew Torque Specifications
Component 32mm 40mm 50mm 50mm
1 Servo Motor - - - -
2a Coupler - Pinch Bolt - Motor Side 15 ft-lb 15 ft-lb 15 ft-lb 30 ft-lb
2b Coupler - Pinch Bolt - Ballscrew Side 15 ft-lb 15 ft-lb 15 ft-lb 30 ft-lb
3a Collar Nut - Pinch Bolt - Bearing Pack End 7 ft-lb 7 ft-lb 7 ft-lb 7 ft-lb
3b Collar Nut on the Bearing Pack End 15 ft-lb 40 ft-lb 40 ft-lb 120 ft-lb
4a Collar Nut - Pinch Bolt - Support End 7 ft-lb 7 ft-lb 7 ft-lb 7 ft-lb
4b Collar Nut on the Support End 4 in-lb 10 ft-lb 10 ft-lb 10 ft-lb
Not Shown Solid Coupler - Pinch Bolts 15 ft-lb 15 ft-lb - -
