UMC-1000 Chip Conveyor Cover Plate - AD0449
Service Home How To Procedures UMC-1000 Chip Conveyor Cover Plate - AD0449
Recently Updated Last updated: 11/10/2020
AD0449
- Jump to Section - 1. Introduction 2. Installation (2 steps) Back to Top
This procedure will show you how to install a cover plate (P/N: 25-13897) on a UMC-1000 chip conveyor.  Install this cover plate, when excessive amount of chips come out the bottom of the conveyor.
Remove the screws from the conveyor brackets [1] and the two screws [2] that secure the extension cover.
Note: To make the installation easier you can remove the bottom left conveyor bracket.
Slightly lift the coveyor [3] and slide back the coveyor extension cover [4] about 3" (76 mm).
Slide back the conveyor [3] about 3" (76 mm).
Remove the two screws [1] that will secure the conveyor cover plate.
Install the cover plate [2] and screw it in place.
Push the conveyor [3] back into place and install the conveyor extension cover [4] back into place.
HSPP, Carbide Shell Mill Insert, Square Positive Positive, Grade HMP20 - Pack of 10 $75.95 $49.97
5/16"-18 UNC HSS-E Spiral Flute Tap, 0.318" Shank x 0.472" Thread Length, 2.5XD, Mod. Bottoming, 2 Flute, GH3, Uncoated $13.95 $8.97
ER20 1/2" Tap Collet, 0.367" Bore Diameter x 0.275" Square $23.95 $13.97
