VMC - 40-Taper - Inline - Bearingless TSC Union - Replacement - AD0344
Service Home How To Procedures VMC - 40-Taper - Inline - Bearingless TSC Union - Replacement - AD0344
Recently Updated Last updated: 10/06/2020
AD0344
- Jump to Section - 1. Introduction (5 steps) 2. VMC - 40-Taper - Inline - Bearingless TSC Union - Replacement (1 step) 3. Classic Haas Control - TSC - 300 and 1K PSI - Test (2 steps) 4. Next Generation Control - TSC - 300 and 1K PSI - Test (2 steps) Back to Top
Do this procedure for these TSC configurations:
  • TSC 300 psi
  • TS 1000 psi (This configuration has the coolant-pump cart.)
  • TSC 1K psi
  1. Bearingless TSC Union
Document Applies to these Parts:
  • KIT PN: 93-2128A, HAAS BGLESS ROT UNION SER 40T 300/1000. QTY: 1
Tools Required:
  • Spindle Lock Tool (T-1635)
  • Red-I Grease
  • Dial Indicator (that can measure 0.0001") with Magnetic Base
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Danger: If the vector drive voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED on the vector drive to go off completely.
Close the primary air valve. Pull the ring on the bleed valve in the air manifold. Wait until all air pressure is released.
Look at the manifold pressure gauge. Make sure that the air pressure is 0 psi.
Remove the spindle head covers.
Install the spindle lock tool (T-1635) onto the spindle.
Remove and record the location of these parts from the bearingless TSC union:
  • high-pressure braided hose [1]
  • 20' (6096 mm) 1/4" gray tube [2]
  • 5' (1524 mm) 1/4" gray tube [3]
  • clamp for the 3/8" black hose [4]
  • 3/8" black hose [5]
Remove these parts from spindle motor:
  • (4) 1/4-20 socket-head cap screws (SHCS) [6]
  • bearingless TSC union [7]
  • (4) standoffs [8]
  • shaft [9]
    Note: Turn the shaft clockwise to remove it.
Do this step if you removed a bearingless TSC union that has an installed regulator assembly [3].
Remove the fitting assembly [2] from the replacement bearingless TSC union [A].
Loosen the (4) 1/4-20 SHCS [4] to remove the regulator assembly [3] from the removed bearingless TSC union.
Loosen the (4) 1/4-20 SHCS [5] to install the regulator assembly [3] on to the replacement bearingless TSC union [A].
Torque the (4) SHCS [5]. Refer to the Haas Fastener Torque Specifications. Use the value for aluminum.
Do these steps to install the shaft [2]:
  • Be sure the threads and o-ring on the shaft [2] are clean.
  • Apply Red-I grease [1] to the o-ring of the shaft [2].
  • Turn the shaft [2] counterclockwise to install it onto the spindle motor.
  • Torque the shaft [2] to 30 ft-lb (41 Nm).
  • Remove the spindle lock tool.
  • Use the dial indicator [3] to measure the total indicated runout (TIR) of the shaft [2].
    Note: The TIR must be less than 0.001" (0.025 mm). If the TIR is more than 0.001" (0.025mm), contact Haas service.
Install these parts on to the spindle motor:
  • (4) standoffs [1] (use the standoffs from the removed bearingless TSC union.)
  • replacement bearingless TSC union [A]
  • (4) replacement washers [B]
  • (4) replacement 1/4-20 x 2" 1/4" SHCS [C]
Unlock the main breaker and push [POWER ON].
Run the spindle at 50 rpm. Make sure the shaft rotates correctly in the bearingless TSC union [A]. If the shaft rotates incorrectly, you will hear a noise from the bearingless TSC union [A].
Lock the main breaker and push [POWER OFF].
Torque the (4) SHCS [1]. Refer to Haas Fastener Torque Specifications. Use the value for aluminum.
Connect these parts to the bearingless TSC union:
  • high-pressure braided hose [2]
  • 20' (6096 mm) 1/4" gray tube [3]
  • 5' (1524 mm) 1/4" gray tube [4]
  • clamp for the 3/8" black hose [5]
  • 3/8" black hose [6]
Operate this code in MDI mode:
  • M59 P1148 ;
  • G04 P5.0 ;
  • M69 P1148 ;
  • G04 P2.0 ;
P1148 is for inline spindles.
For HS machines, use P1124 and not P1148.
For belt-drive spindles, use P1120 and not P1148.
If the machine has a bearingless TSC union, it moves up and down at 7-second intervals. The up and down movement is small.
The illustration shows the up and down movements for 40-taper [1], 40-taper (CALM) [2], and 50-taper [3] machines.
Put a TSC toolholder [1] in the spindle. Push [AUX CLNT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder.
  2. A few drops flow from the vacuum-generator hose [2].
Push [RESET].
Install the spindle-head cover panels.
Operate this code in MDI:
  • M59 P26 ;
  • G04 P5.0 ;
  • M69 P26 ;
  • G04 P2.0 ;
  • M99 ;
P26 is for inline spindles.
For belt-drive spindles, use P35 and not P26.
The bearingless TSC union moves up and down at 7-second intervals. The up and down movement is small.
Push [RESET].
