Haas Bar Feeder - Torsion Bar Upgrade Kit
Service Home Service Updates Haas Bar Feeder - Torsion Bar Upgrade Kit
July 14, 2021 Haas Bar Feeder - Torsion Bar Upgrade Kit
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
Symptom:
The Push Rod is bent after loading or unloading onto the Bar Pusher.
Cause:
The Push Rod Arms lower or raise out of sync.
Solution:
First check the Push Rod Alignment. If it is correct and the issue continues. Upgrade the Bar Feeder with the Haas Bar Feeder - Torsion Bar Upgrade Kit. This kit connects both Push Rod Arms together to keep them in sync when raising and lowering to prevent jamming and bending of the Push Rod during operation.
This service kit applies to Haas Bar Feeders built 02/09/2015 and later:
  • 93-3384 - BARFEEDER TORSION BAR SERVICE KIT
WNMA432-HMA / WNMA080408-HMA, Carbide Turning Insert, Trigon, Grade HTK10 - Pack of 5 $34.95 $22.97
BOT10, 20mm Square Shank Static Face Grooving Holder $404.95 $263.97
