      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
Hardness Tester
Portable EDM
LATHE JAWS
HAAS TESTED. HAAS PROVEN.
SEE ALL LATHE JAWS
BUY A BORING RING &
GET 50% OFF 2 SETS OF SOFT JAWS
START SAVING | LEARN MORE
*Limit to 2 soft jaw sets per boring ring. Pie jaws and 15" jaws are not included. The lowest-priced soft jaws will be discounted. Discount will be displayed in your cart.
  2. Lathe Workholding
  3. Lathe Jaws
Lathe Chuck Sizes & Serrations
MATCHING CHUCK SIZES & JAW SERRATIONS
___________________________________________________________________
Before selecting the jaw type that is right for you, it is important to match the jaw size to your lathe chuck diameter, and to the serrations of that chuck. Haas Tooling offers jaws for lathe chucks ranging from 5" (135 mm) - 15" (381 mm) in diameter, and all of our jaws have 1.5 mm x 60° serrations, which are compatible with most CNC lathe chucks.
*These jaws are for hydraulic power chucks with fine jaw serrations.  These are standard on Haas ST and DS models.  Haas Toolroom Lathes, TL-1 and TL-2, use manual scroll-type chucks with different jaws.
SORT BY YOUR LATHE CHUCK SIZE
5" (135 mm) CHUCK SIZE
6" (165 mm) CHUCK SIZE
8" (210 mm) CHUCK SIZE
10" (254 mm) CHUCK SIZE
12" (305 mm) CHUCK SIZE
15" (381 mm) CHUCK SIZE
Lathe Jaw Types
WHAT HAAS TOOLING JAW TYPE DO I NEED?
Picking the right jaw type for your workholding application can be tough. To make it easier, review the 3 lathe jaw types that Haas Tooling offers. Also, remember that these jaw types are machinable for your specific part clamping needs.
Standard Point Jaws
  • Pointed ends allow better clamping on smaller diameter parts
  • Suitable for most workholding applications
  • Great for smaller diameter parts
  • Available in steel and aluminum
SHOP STANDARD POINT JAWS
Standard Flat Jaws
  • High surface contact for better part gripping and higher accuracy
  • Machinable to a precise diameter for your application
SHOP STANDARD FLAT JAWS
Round/Pie Jaws
  • Almost 360° of surface contact for maximum part gripping and accuracy
  • Machinable for your specific part application
  • Great for large-diameter, thin-section, and non-cylindrical parts
  • Available in aluminum only
SHOP ROUND/PIE JAWS
Aluminum or Steel?
WHICH MATERIAL SHOULD I USE WHEN CLAMPING MY PART?
_______________________________________________________________________________
Aluminum
  • Should be used to hold aluminum or softer parts, like brass or copper
  • Great for prototyping parts
  • Capable of holding small, thin, steel parts with a better grip
SHOP ALUMINUM JAWS
Soft Steel
  • High durability for large-volume production runs
  • Will not deform as easily as other materials
  • Should be used when clamping harder and stronger materials
  • Can still be machined to your part applications
SHOP SOFT STEEL JAWS
Video
Lathe Soft Jaws, Boring Rings, and VPS Templates
Product Specialist Bhop Singh discusses the various lathe soft jaws and boring rings available on HaasTooling.com, and demonstrates how to quickly create a program for boring step jaws, using the VPS template in the Haas control.
Explore our selection of CNC lathe soft jaws crafted from both aluminum and soft steel for versatile workholding solutions. Designed for precision and durability, our soft jaws ensure secure clamping of irregularly shaped or delicate workpieces during machining operations.
