      • Rotary Workholding Kits
SHELL MILL HOLDERS
HAAS TESTED. HAAS PROVEN.
SEE ALL END MILL HOLDERS
  2. Mill Toolholding
  3. Shell Mill Holders
SHELL MILL HOLDERS
These high-quality shell mill toolholders are constructed of hardened alloy steel, and designed to hold a wide variety of arbor-style shell mill and face mill cutters. They are balanced to a G2.5 rating at 20,000 rpm, and have removable drive keys for added versatility.
NOTE: These shell mill holders are coolant-through capable. However, the included arbor screws are not coolant-through. You will need to purchase the appropriate coolant-through arbor screw to use through-spindle coolant cutters.
  Benefits:
  • Constructed of alloy tool steel for long, durable service life
  • Hardened to RC 56-60 for long service life
  • Black oxide finish for the best combination of accuracy and durability
  • Shell mill pilot TIR < .0002"
  • Balanced to G2.5 at 20,000 rpm
Toolholder and Pull Stud specifications
Toolholder Maintenance
Upgrade your machining capabilities with our selection of shell mill holders. Find a range of holders, including BT, CAT, SK40, SK50, and HSK types, for secure and precise milling operations.
