10k Inline Spindle (10K-40T-GREASE-IN)
Product Image
GET QUOTE
10,000-rpm Inline Grease-Packed Spindle
    CNY ONLY
Optional inline spindle for 40-taper mills
  • 10k Speed
  • 40 Taper
  • Inline Drive
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 10,000-rpm inline direct-drive spindle provides high rpm, without sacrificing low-speed torque or high-speed power. The grease-packed design is ideal for machining materials that cannot be contaminated by oil from a standard air/oil lubricated spindle. This system features a Haas-built cartridge spindle that is coupled directly to the motor to reduce heat, increase power transmission, and provide excellent surface finishes. This spindle provides a good combination of torque and rpm for a wide selection of machining operations.
NOTE: This option does not change the horsepower/kW rating or power requirement of the machine.
  • Faster spindle speeds allow higher feedrates
  • Ideal for materials like wood and plastics that cannot be contaminated by oil
  • Increased performance when using small cutting tools and machining softer materials
Service Documents
Need More Information?
