      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
20k Spindle, DC Series (20K-30T-IN-DC)
Product Image
GET QUOTE
20,000-rpm Spindle, DC Series
    CNY ONLY
High-speed spindle for DC Series
  • 20k Speed
  • 30 Taper
  • 15 hp Power
  • Inline Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 20,000-rpm spindle provides the necessary power and speed for high-production environments. The higher rpm range produces superior surface finishes, and the combination of high speed and fast accel/decel rates results in shorter cycle times. The 20k spindle is an excellent way to enhance the performance and productivity of the DC Series machines.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
  • Increases production by increasing material removal rates due to the high rpm range
  • Improves surface finishes by maintaining a constant high surface speed
  • Reduces cycle time through high accelerations and decelerations
  • Optimizes tool life by allowing proper surface speeds, particularly on small tools, preventing premature tool wear
  • Compatible with the Haas 300 psi (21 bar) through-spindle coolant system.
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
