      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
High-Speed 120+1 Side-Mount , HSK (SMTC-120-HSK-HS)
Product Image
GET QUOTE
High-Speed 120+1 Side-Mount Tool Changer, HSK
    CNY ONLY
High-speed tool changer for HSK-taper mills
  • HSK-A63 taper
  • Remote load station with automatic lockout
  • Bi-directional servo-driven positioning for fast tool staging
  • Mounts to the machine’s bridge and base for stability
  • High-speed tool changes reduce non-cutting time
  • Tool Table allows complete control over the tool changer
  • Identify tools as LARGE to leave adjacent pockets empty
  • Identify tools as HEAVY to slow tool changer motion
  • 120+1 Tools
  • HSK-A63 Taper
  • Side-Mount Type
  • Option Info
OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
This Haas-designed 120+1 side-mount tool changer holds 120 tools, plus one in the spindle, providing plenty of locations for back-up tooling, or setting up tools for multiple jobs. It is the perfect choice for high-volume production, or for unattended, lights-out operation with a pallet pool, cobot, or robot.
The tool changer features a high-speed double-arm gripper that swaps tools quickly to minimize non-cutting time, and a bi-directional servo-drive system allows direct positioning to any tool in the carousel. Faster positioning reduces cycle times during short machining operations, or when the carousel is not pre-staged for the next tool. A remote load station with automatic lockout function allows tool inspection, loading, and unloading while the machine is cutting, simplifying tool maintenance, and eliminating the need to load tools through the spindle.
With adjacent pockets empty, the tool changer will accept oversize tooling, and there’s a built-in automatic recovery process, should a tool change be interrupted for any reason.
SERVICE DOCUMENTS
Haas UMC-750
UMC-750
5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Haas UMC-750SS
UMC-750SS
Super-Speed 5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 5 Axis
  • 12k RPM
    CNY ONLY
Need More Information?
