G-code, M-code, and Setting
Service Home 164 - Rotary Increment
This setting applies to the [PALLET ROTATE] button on the EC-1600. It specifies the rotation for the rotary table. It should be set to a value from -180 to 180.For example, entering 90 rotates the pallet 90 degrees each time the rotary index button is pressed. If it is set to zero, the rotary table does not rotate.
NOTE
For software 100.24.000.1100 or later, use settings 435 to 440.If the User Positions indexer settings are disabled (settings 435 to 440 = inactive and 0), pressing the mechanical button will still use the setting 164 value.
