Ballscrew - Installation Tools and Torque Specifications
Service Home How To Procedures Ballscrew - Installation Tools and Torque Specifications
Recently Updated Last updated: 06/25/2021
- Jump to Section - 1. Introduction 2. Ballscrew - Installation Tools 3. Ballscrew - Torque Specifications Back to Top
    This document tells you the tools you need to install ballscrew components and the correct torque specifications for those components.
Tool 32mm 40mm 50mm
50mm
(Larger Motor Housing)
A Coupler - Installation Tool - "Pacman" Note: This spacer is included with the coupler.
B Collar Nut Socket- Bearing Pack End
T-1069 (Short)
T-0047 (Long)
T-1542A T-1542A T-2098
C Collar Nut Socket- Bearing Support End
T-1069 (Short)
T-0047 (Long)
T-1542A T-1542A T-1542A
D Collar Lock Tool - Bearing Pack End T-1601 T-1555 T-1555 T- Handle
E Collar Lock Tool - Bearing Support End T-1601 T-1555 T-1555 T-1555
F Hex Bit for the Collar Nut - Pinch Bolt
Hex bit; 4mm X 1/4" drive X 4"
G Hex Bit for the Coupler
Hex bit; 3/16" X 1/4" drive X 4" Hex bit; 6 mm X1/4" drive X 4"
H Torque Wrench Adapter for 1/4" Hex Bit Adapter; 3/8" socket drive to 1/4" female hex
I Torque Wrench
Component 32mm 40mm 50mm
50mm
1 Servo Motor - - - -
2a Coupler - Pinch Bolt - Motor Side 15 ft-lb 15 ft-lb 15 ft-lb 30 ft-lb
2b Coupler - Pinch Bolt - Ballscrew Side 15 ft-lb 15 ft-lb 15 ft-lb 30 ft-lb
3a Collar Nut - Pinch Bolt - Bearing Pack End 7 ft-lb 7 ft-lb 7 ft-lb 7 ft-lb
3b Collar Nut on the Bearing Pack End 15 ft-lb 40 ft-lb 40 ft-lb 120 ft-lb
4a Collar Nut - Pinch Bolt - Support End 7 ft-lb 7 ft-lb 7 ft-lb 7 ft-lb
4b Collar Nut on the Support End 4 in-lb 10 ft-lb 10 ft-lb 10 ft-lb
Not Shown Solid Coupler - Pinch Bolts 15 ft-lb 15 ft-lb - -
