TRT Zero Point Installation - AD0658
Service Home How To Procedures TRT Zero Point Installation - AD0658
Recently Updated Last updated: 08/12/2025
Rotary - Zero Point - Install
AD0658
Revision A - 8/2025
- Jump to Section - 1. Introduction 2. Installation (5 steps) Back to Top
A TRT160 or TRT210 ordered with the Zero Point work holding option will require some assembly before it can be used.
This procedure goes over how to set up a new TRT with a zero-point option.
Note: This option is not field installable.
This document does not go over how to install the air clamp provision. Instructions can be found on AD0524 TRT Rotary - Air Clamp Provision - Installation.
Instructions for setting up programable air and automatic work holding on NGC can be found on AD0473 Programmable Air - Installation.
The instructions for installing a rotary can be found on AD0005 Rotary - Installation.
The instructions for managing rotary cables can be found on AD0530 Rotary Cable Management Kit - Installation.
Required tools
  • 59-1844B - Zero Point Clamp
  • 59-1867 - Zero Point Plate or other work holding with Zero Point pull stud.
  • Indicator with a mag base
  • Torque wrench with 5 mm hex bit
  • Grease
Machine requirements
  • 100.20.000.1200 version or Higher
  • Minimum Main IO firmware: version 4.0 or higher
 Warning: The air clamp provision must be installed before starting this procedure. If it is not installed, follow the instructions on AD0524 TRT Rotary - Air Clamp Provision - Installation.
Place the TRT in the machine, plug the TRT into the machine, and connect it to an air source.
Blow air thru both ports located on the rear of the unit marked Aux 1 and Aux 2 to ensure the plumbing to the union/plate is free of debris.
If the TRT has the manual clamp, flip the switch to blow air through the TRT.
If the TRT has the auto clamp, use the foot petal or M codes M70 and M71.
The air will come out of the top of the rotary axis [1].
The image shows the bottom side of the Zero Point chuck. In the three noted grooves, install O-rings as shown on the vise. Use grease to hold o-rings in place.
Orient the vise as shown and carefully insert it into the bore. It’s a close fit, so be careful.
Position #1 [1] should be between the two air outlets [2].
Use a torque wrench with a 5 mm bit to torque down the eight bolts to 8 ft-lbs or 104 in-lbs or 11.8 Nm.
Use an indicator to check the runout of the chuck. It should be NTE 0.0005 inches or 0.0127 mm.
Place a work holding plate on the rotary and test that it clamps and unclamps correctly.
