Umbrella Tool Changer - Shuttle Roller - Replacement
Service Home How To Procedures Alarm Search: 966 Umbrella Tool Changer - Shuttle Roller - Replacement
Recently Updated Last updated: 04/24/2025
Revision C - 4/2025
- Jump to Section - 1. Shuttle Roller - Replacement - Introduction 2. Shuttle Roller - Replacement (3 steps) 3. Verification (2 steps) Back to Top
This procedure tells you how to replace the top [1] and bottom [2] shuttle rollers on an umbrella tool changer.
Tools Required:
  • Mobil 460 Grease
  • Bottle Jack
  • Medium-strength thread-lock compound
Remove all tools from the tool changer.
Put wooden blocks on the table. Put a bottle jack on the wooden blocks.
Jog the table below the center of the carousel plate.
Support the carousel plate with the bottle jack.
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Top roller replacement:
Loosen the (2) 5/16-18 x 2 Socket Head Cap Screws (SHCS) [1]. Remove the wiper bracket [2].
Remove the SHCS [1], lock washer [3], flat washer [4], and roller [5].
Apply medium-strength thread-lock compound (for example, blue Loctite®) to the (2) SHCS [1]. Replace the roller [5] and bushing [6]. Install the components in the opposite sequence they were removed. Make sure the roller [5] is tight against the V-rail [7].
Torque the SHCS [1] to 20 ft-lb (27 N-m). Apply Mobil 460 grease to the top V-rail [7].
Bottom roller replacement:
Remove the 5/16-18 x 1 3/4 Hex Head Bolt (HHB) [1], lock washer [2], flat washer [3], and roller [4].
Apply medium-strength thread-lock compound (for example, blue Loctite®) to HHB. Replace the roller [4] and eccentric bushing [5]. Install the components in the opposite sequence they were removed. Make sure the roller [4] is tight against the V-rail [6].
Rotate the eccentric bushing [5] until the roller is tight on the rail.
Torque the HHB [1] to 20 ft-lb (27 N-m). Apply Mobil 460 grease to the bottom V-rail [6].
IMPORTANT: Hold the lower guide bushing in place with a wrench while torquing the HHB. Over-torquing will cause damage to HHB and eccentric bushing.
Verification
Test the umbrella tool changer for correct operation.
Visually inspect the roller to verify the carousel is not binding and is properly aligned as shown in the image.
Remove the cam follower assembly [1] and lower the slip clutch arm [2] to move the carousel assembly from the shuttle in position, to the shuttle out position in order to verify there are no binds.
If the carousel does not bind, re-install the cam follower assembly.
Refer to the VMC - Umbrella Tool Changer to Spindle - Alignment procedure.
