8M PCB - Troubleshooting Guide - NGC
Service Home Alarm Search: 4.103 8M PCB - Troubleshooting Guide - NGC
Recently Updated Last updated: 07/10/2023
Jump to Section Back to Top
The 8M Relay PCB is an option that adds (8) additional outputs to the I/O PCB. Additional outputs can be used to activate probes, auxiliary pumps, or clamping devices.
Please refer to the user manual for detailed descriptions on all of the M-Codes and functions related to the 8M option.
 Note: The 8M PCB option does not provide an output voltage, it only provides an NC or NO switch point for the user interface.
There are two main uses of the 8M:
  • Turn relays on (M59) and off (M69)
  • Turn relays on while waiting for an external finish signal before turning relay off (Mill: M29, Lathe: M129)
Each M code is followed with a P code. The M codes turns the relay on/off while the P code addesses the discrete relay being turned on/off.  For more information, refer to the M-Code Relay Function - NGC and Robot Integration Aid - NGC reference document.
The M21-M28 relays on the 8M PCB do not activate when commanded. There is a problem with the power to the 8M PCB. Troubleshoot the power to the 8M PCB.
The M21-M28 relays on the 8M PCB do not activate but their corresponding LED indicates they are on. There is a problem with the relays. Make sure the relays are not damaged.
The relays on the M-code PCB are not resetting with [RESET], [E-STOP] or Alarm. The software is outdated See the Reset Behavior section below.
For machines built after 2019 without pallet changer: Some P codes on Bank #2 do not activate when commanded.  Bank #2 only uses outputs P106 - 109 for this configuration.  For more outputs, switch bank #2 with bank #3 in order to use outputs P79 - P86.
Input Voltage Inspection
Corrective Action:
Measure the voltage at P2 on the 8M PCB. Use a multimeter with needle-tip probes. The voltage must be 12 VDC.
 Note: Do not measure the voltage with the cable disconnected.
If the voltage is not correct, measure the voltage at P35 on the PSUP PCB. The voltage must be 12 VDC.
If the voltage is correct, cable 860 is at fault. If the voltage is not correct, troubleshoot the PSUP PCB.
Relay Inspection
Corrective Action:
Make sure the relays are not damaged. Make sure there is continuity between the contacts on the terminal block:
  • Disconnect the cables from the terminal that is at fault.
  • Activate the relay. Check for continuity across the Normally Open (NO) contact and the Common (COM) contact.
  • De-activate the relay. Check for continuity across the Normally Closed (NC) contact and the (COM) contact.
Make sure the coil of the relay is not open:
  • Remove the 8M PCB. On the back of the 8M PCB, measure the resistance across pins 1 and 5 of the relay at fault.
  • If the measurement is open, the coil of the relay is open. The 8M PCB is at fault.
Electrical Diagram
