      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Parts Catcher (PCAT) - Troubleshooting Guide
Service Home Parts Catcher (PCAT) - Troubleshooting Guide
- Jump to Cause - Back to Top
12.2 parts catcher - troubleshooting guide
Recently Updated Last updated: 10/08/2024
PCAT - Troubleshooting Guide
This procedure shows you how to troubleshoot the Parts Catcher system on all ST machines.
Slow depolyment / moving chute Lack of lubrication / Chip build up Refer to Lubrication section below
Faulty rotary damper Refer to Actuation section below
Lack of air supply
Check all air lines are porperly connected and verify solonoid functionality
Clean the highlighted surfaces [1] and [2] from any debris / metal chips / coolant residue then grease the blue surface [2].
Actuation
If your PCAT is experiencing slow or excessivly fast deployment it may be due to a worn out damper.
Replace the rotary damper [2] by simply removing the covering sheet metal and hardware [1].
Note : An updated damper P/N 59-2164 is reccomended for this replacement and is included in Svc Kit 93-3771 PCAT SVC KIT 3 N.M DAMPER ST-10/20/30
