C-Axis Correction - NGC Lathe
Service Home Service Updates C-Axis Correction - NGC Lathe
August 23, 2018 C-Axis Correction: NGC Lathe
Problem:  A limited amount of NGC lathes shipped with the C-axis engagement offset set wrong. The C-axis disk also needs to have the runout checked and adjusted if needed.
Solution:  Use a dial indicator to check the runout of the C-axis disc. If adjustment of the disc is performed, the depth of the C-axis pinion gear engagement needs to be reset. After this is completed, the C-axis engagement offset needs to be set. The NGC lathe no longer uses the C-axis tool change offset parameter for engagement.  To achieve alignment of the C-axis servo motor to the C-axis drive gear, we simply set the spindle orient offset parameter to align with the C-axis, when the C-axis is at its home position.
If you have an NGC Lathe in your area that is experiencing problems with the C-axis, perform the C-Axis Engagement Offset - NGC Lathe procedure.
